iLogic - Displaying Named Geometry labels?
Will.Ehrendreich
Will.Ehrendreich
Hello!
Thanks for taking a look! I appreciate it!
I'm just trying to figure out if I can display the Named Geometry labels via ilogic/api.
I know I can just go into a part, into the geometry tab and make them visible, but it would be nice to be able to do it from the assembly level with a button or something..
Any Ideas?
Thanks so much!
Will
Accepted solutions (3)
bradeneuropeArthur
take a look at this post...
https://forums.autodesk.com/t5/inventor-customization/geometry-labels-inventor-2019/td-p/8338273
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Will.Ehrendreich
Hey,
Thanks so much!
do I still mark it as a solution if the answer is... the api doesn't support it yet.. lol. you answered my question, but it's not a "solution" per se, so I'm legitimately not sure what the custom is.
i appreciate the link though!
Will
bradeneuropeArthur
Sure you always can!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
