vb.net error
vb.net error
^_^clovis^_^
vb.net error
^_^clovis^_^
I'm trying to compile my own tm_chrome.dll for Inventor. after the compiling I get an error which from which I can't find the source : Thanks a lot for any pointers
The command "    	if exist "%ProgramFiles%\Microsoft SDKs\Windows\v6.0\bin\mt.exe" set var="%ProgramFiles%\Microsoft SDKs\Windows\v6.0\bin\mt.exe"		if exist "%ProgramFiles%\Microsoft SDKs\Windows\v7.0\bin\mt.exe" set var="%ProgramFiles%\Microsoft SDKs\Windows\v7.0\bin\mt.exe"		if exist "%ProgramFiles%\Microsoft SDKs\Windows\v6.0A\bin\mt.exe" set var="%ProgramFiles%\Microsoft SDKs\Windows\v6.0A\bin\mt.exe"		if exist "%ProgramFiles%\Microsoft SDKs\Windows\v7.0A\bin\mt.exe" set var="%ProgramFiles%\Microsoft SDKs\Windows\v7.0A\bin\mt.exe"		if exist "%PROGRAMFILES(x86)%\Microsoft SDKs\Windows\v6.0A\bin\mt.exe" set var=%PROGRAMFILES(x86)%\Microsoft SDKs\Windows\v6.0A\bin\mt.exe"		if exist "%PROGRAMFILES(x86)%\Microsoft SDKs\Windows\v7.0A\bin\mt.exe" set var="%PROGRAMFILES(x86)%\Microsoft SDKs\Windows\v7.0A\bin\mt.exe" 		if exist "%PROGRAMFILES%\Windows Kits\8.0\bin\x64\mt.exe" set var="%PROGRAMFILES%\Windows Kits\8.0\bin\x64\mt.exe"		if exist "%PROGRAMFILES%\Windows Kits\8.0\bin\x86\mt.exe" set var="%PROGRAMFILES%\Windows Kits\8.0\bin\x86\mt.exe"		if exist "%PROGRAMFILES(x86)%\Windows Kits\8.0\bin\x64\mt.exe" set var="%PROGRAMFILES(x86)%\Windows Kits\8.0\bin\x64\mt.exe"		if exist "%PROGRAMFILES(x86)%\Windows Kits\8.0\bin\x86\mt.exe" set var="%PROGRAMFILES(x86)%\Windows Kits\8.0\bin\x86\mt.exe"		call %var% -manifest "c:\users\masse\documents\visual studio 2015\Projects\tm_chrome\tm_chrome\LengthSweep.X.manifest" -outputresource:"c:\users\masse\documents\visual studio 2015\Projects\tm_chrome\tm_chrome\bin\Debug\tm_chrome.dll";#2    " exited with code 1.
jjstr8
You shouldn't need a manifest.  I don't generate one for add-ins.
HideoYamada
The source of that message is written in :
1) Right click the project in Solution Explore.
2) Left click the 'Property'.
3) Left click the 'Compile' tab.
4) Left click the 'Build event' button.
5) You can see it in the 'Build event' window.
This error occurs when mt.exe is not installed. You should install Windows SDK or such like it.
https://developer.microsoft.com/en-us/windows/downloads/windows-10-sdk
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
^_^clovis^_^
Hello Jjstr8,
The addins works fine. I just wanted to avoid this error message.
jjstr8
Just delete that part of your post-build event.  Assuming you're building a single DLL with all resources embedded, you wouldn't need a manifest.
