ilogic Configurator for Model eventually to configure Drawing.
RaySWE
RaySWE
Hello all,
 Currently making an ilogic configurator to use on Models specifically assemblies. Currently
 just working on one assembly configurator at the moment. With that said, I have a small idea of what the next steps would be to bring over a model to a drawing as the company I work for has a drawing package.
I am curious about how I can or should tie an assembly over to a drawing package in order to minimize or eliminate mundane tasks for Mech Engineers?
What would a good solid recommended way be of doing this to connect an assembly configured by a configurator to then be tied in to a drawing package.
I know this might be vague and to anyone asking for more detail please do, because context matters.
As a new forum member I'm excited to be here and to learn from you all.  🙂
Design Automation | Drawing Automation
bradeneuropeArthur
Maybe create a multi-sheet drawing with for example:
Sheet 1 the assembly and the built up "Arrangement"
Sheet 2 and further the piece parts mono drawings.
Use this complete as a template (Assembly, Parts, drawings).
Use Copy Design for creating variants/versions of this design.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
marcin_otręba
I would use update model reference in existing assembly drawing functionality togheter with re-scaling of views.
Drawing must be prepared correctly - fully consterained section lines attached to valid geometry, the same - attached detail views, good views and dimmensions arrangement to minimalize user work, connected with drawing checker to inform user if any error occured.
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders   auto-save-replace
