iLogic code not working perfectly
GKPByDesign
GKPByDesign
I am have an issue with this logic with the attached file.
1. Model_Type remain blank, but should only be blank as written in code as Model_Type=""
2. MOD appears as True when MOD="" in code
Can someone help
Everything else works fine!
If Cut = "Box Section - No Cut" Then
Feature.IsActive("Box Section") = True
Feature.IsActive("U Channel") = False
Feature.IsActive("Angle Section") = False
Feature.IsActive("Model A") = False
Feature.IsActive("Model A - Small Side") = False
Feature.IsActive("Model B") = False
Feature.IsActive("Model B - Small Side") = False
Feature.IsActive("Model C") = False
Feature.IsActive("Model D") = False
Feature.IsActive("Model E") = False
Feature.IsActive("Model F") = False
Feature.IsActive("Angle Section - Single Cut") = False
Feature.IsActive("Box Section - Single Cut") = False
Angle_1_PA = "0.1" & Angle_2_PA = "0"
Angle_1_PA = "0"
Angle_2_PA = "0"
iProperties.Value("Custom", "Model_Type") = ""
iProperties.Value("Custom", "MOD") = Model_Type
ElseIf Cut = "Angle Section - No Cut" Then
Feature.IsActive("Box Section") = False
Feature.IsActive("Angle Section") = True
Model_Type = "" & Angle_1_PA = "0.1" & Angle_2_PA = "0"
Angle_1_PA = "0"
Angle_2_PA = "0"
ElseIf Cut = "U Channel - No Cut" Then
Feature.IsActive("U Channel") = True
Angle_1_PA = "0"
Angle_2_PA = "0"
ElseIf Cut = "Box Section - Model A" Then
Feature.IsActive("Model A") = True
Model_Type = "Model A"
ElseIf Cut = "Box Section - Model A - Small Side" Then
Feature.IsActive("Model A - Small Side") = True
ElseIf Cut = "Box Section - Model B" Then
Feature.IsActive("Model B") = True
Model_Type = "Model B"
ElseIf Cut = "Box Section - Model B - Small Side" Then
Feature.IsActive("Model B - Small Side") = True
ElseIf Cut = "Angle Section - Model C" Then
Feature.IsActive("Model C") = True
Model_Type = "Model C"
ElseIf Cut = "Angle Section - Model D" Then
Feature.IsActive("Model D") = True
Model_Type = "Model D"
ElseIf Cut = "Angle Section - Model E" Then
Feature.IsActive("Model E") = True
Model_Type = "Model E"
ElseIf Cut = "Angle Section - Model F" Then
Feature.IsActive("Model F") = True
Model_Type = "Model F"
ElseIf Cut = "Box Section - Single Cut" Then
Feature.IsActive("Box Section - Single Cut") = True
Angle_2_PA = "0"
Model_Type = "Single Cut"
ElseIf Cut = "Angle Section - Single Cut" Then
Feature.IsActive("Angle Section - Single Cut") = True
Angle_2_PA = "0"
bradeneuropeArthur
Change this in general...
Dim Model_Type as string
If Cut = "Box Section - No Cut" Then Feature.IsActive("Box Section") = True Feature.IsActive("U Channel") = False Feature.IsActive("Angle Section") = False Feature.IsActive("Model A") = False Feature.IsActive("Model A - Small Side") = False Feature.IsActive("Model B") = False Feature.IsActive("Model B - Small Side") = False Feature.IsActive("Model C") = False Feature.IsActive("Model D") = False Feature.IsActive("Model E") = False Feature.IsActive("Model F") = False Feature.IsActive("Angle Section - Single Cut") = False Feature.IsActive("Box Section - Single Cut") = False Feature.IsActive("U Channel") = False Angle_1_PA = "0.1" & Angle_2_PA = "0" Angle_1_PA = "0" Angle_2_PA = "0" iProperties.Value("Custom", "Model_Type") = "" iProperties.Value("Custom", "MOD") = Model_Type ElseIf Cut = "Angle Section - No Cut" Then Feature.IsActive("Box Section") = False Feature.IsActive("U Channel") = False Feature.IsActive("Angle Section") = True Feature.IsActive("Model A") = False Feature.IsActive("Model A - Small Side") = False Feature.IsActive("Model B") = False Feature.IsActive("Model B - Small Side") = False Feature.IsActive("Model C") = False Feature.IsActive("Model D") = False Feature.IsActive("Model E") = False Feature.IsActive("Model F") = False Feature.IsActive("Angle Section - Single Cut") = False Feature.IsActive("Box Section - Single Cut") = False Feature.IsActive("U Channel") = False Model_Type = "" & Angle_1_PA = "0.1" & Angle_2_PA = "0" Angle_1_PA = "0" Angle_2_PA = "0" iProperties.Value("Custom", "Model_Type") = Model_Type
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
GKPByDesign
Sorry can you elaborate ?
bradeneuropeArthur
What is Model_Type meant in this?
I assume the Custom Property Model_Type
It seems that it is not declared.
Declare it first with Dim Model_Type as string with a value of course.
If the value is missing it does not work
What is MOD meant in this?
I assume the Custom Property MOD.
Is the Custom property always available?
Otherwise you need a try catch.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
GKPByDesign
The code can be split into around 10 different processes, and if 1 process is done it does a few extra steps with varying results. I am coming across two issues: Take the first paragraph:
Angle_1_PA = "0"
Angle_2_PA = "0"
 Model_Type & MOD are the same parameter I require them both, they are simply text values. The above paragraph if run, will fail at two things.
1. When you run the above, Model_Type should be blank, which it is, however it is always blank, even when its not supposed to be? I don't know why this is
2. MOD copies Model_Type, and in most instances if there is a value for Model_Type it copies fines, but when I ask for Model_Type to be "" (blank) it cannot copy this at all and inputs "True" instead
Hopefully this now makes a little more sense.
To answer your reply,
I need Model_Type to be Blank when written as above ""
This captures correctly when there is a value for Model_Type, however becomes "True" when the value of Model_Type supposed to be blank
smilinger
These lines cause the problem:
Angle_1_PA = "0"
Angle_2_PA = "0"
Angle_1_PA = "0"
Angle_2_PA = "0"
Angle_1_PA = "0"
Angle_2_PA = "0"
You can't join multiple assignment statements into one line with "&" in VB.
GKPByDesign
Amended to what you've said, and its still functional however when I want the code to be blank as in "" it won't pick up that value, any ideas a better way to leave something blank in ilogic?
