Ignore vault checkout message in inventor API
basnederveen
Message 1 of 35
basnederveen
Hi everyone,
I was wondering if it was possible to press NO on the 'Do you want to check this item out from Vault?' prompt in an add-in/macro?
Turning on silentoperation does not work for this. I know the commandmanager gives me the option to check-in, out and undo-check-out my files, but I haven't been able to find what I am looking for.
Thanks in advance
Bas
Replies (34)
Message 21 of 35
bradeneuropeArthur
I will explain the serialization later, ok?
Please send me I private message if you want this explanation. otherwise I will forget it.
other question is:
Why does your macro's try or want to check out the not checked out files form vault.
is it not much easier to prevent them form checking out in your macro?
I am running also a lot or routines (Vb.net) but not for files that are not checked out!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 22 of 35
basnederveen
sent the message. Thank you!
I am trying to make a batch exporter, but i need to do something to each drawing. So i get the vault popup on file edit, and the macro stops..
I think for now I am gonna go with disabling the vault addin and enabling it after finishing.
Message 23 of 35
bradeneuropeArthur
Hi Bas,
You could also save the file with a temporary name and location "strfullfilename".
open this file "strfullfilename" with :
oInvApp.FileOptions.FileOpenOptions.SkipAllUnresolvedFilesInDrawing = True
InventorApplication.Documents.OpenWithOptions(strfullfilename, oNVM, True)
This will eliminate vault from watching it.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 24 of 35
m_zano
I found your solution and would like to use it;
1 - I imported the Connectivity.Inventor.Forms dll into the references of my Win Form project in Visual Studio 2017
2 - 64-bit CPU target
3 - I have included these two instructions in the project
Connectivity.Inventor.Forms.SuppressCheckInDialog.SuppressSetting = True invApp.CommandManager.ControlDefinitions.Item ("VaultCheckinTop"). Execute2 (False)
but unfortunately Inventor keeps showing me the check-in dialog.
To do this type of setUp, can inventor be turned on with an open assembly or do I have to set these settings in some particular condition?
Thank you very much
Message 25 of 35
bradeneuropeArthur
Did you save the file temporary?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 26 of 35
m_zano
I don't think is my solution....
I want to check in my open drawing file by
invApp.CommandManager.ControlDefinitions.Item("VaultCheckinTop").Execute2(False)
and I would like to use your instruction
in order to flag this checkbox via API before perform the check in command "invApp.CommandManager.ControlDefinitions.Item("VaultCheckinTop").Execute2(False) "
is it possible to do it? I am not able to obtain this behavior
Message 27 of 35
bradeneuropeArthur
Then you will need to use the EDM add-in reference of inventor.
There you can disable it first and enable the dialog afterwards.
Also the option can be disabled from the options in the Vault tab.
regards,
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 28 of 35
m_zano
I have imported Connectivity.InventorAddin.EdmAddin but
doesn't work correctly because inventor continues to show me the Check In dialog windows
Message 29 of 35
bradeneuropeArthur
Ok, that is strange!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 30 of 35
m_zano
Shoud it works? Inventor continue to show me the Dialog....do you see some errors?
Imports Inventor
Imports Connectivity.Inventor.Forms
Imports Connectivity.InventorAddin.EdmAddin
Public Class Form1
Dim invApp As Inventor.Application
Dim inventorAppType As Type = System.Type.GetTypeFromProgID("Inventor.Application")
Private Sub ButtonTest_Click(sender As Object, e As EventArgs) Handles ButtonTest.Click
invApp = GetObject(, "Inventor.Application")
Debug.Print(Connectivity.Inventor.Forms.SuppressCheckInDialog.SuppressSetting)
End Sub
End Class
Message 31 of 35
bradeneuropeArthur
Did you use this too?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 32 of 35
bradeneuropeArthur
(I think) This only works with an Add-in.
You use it as application and that does not work!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 33 of 35
m_zano
Hi
thank you very much ... I have developed a simple addIn and now it works.
I have another (last) question ... do you know if is possible to set or change this answers via API?
Thank you
Manuele
Message 34 of 35
bradeneuropeArthur
See one of my ideas for the Vault prompts.
So answer: This is not implemented yet!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 35 of 35
Tobias_96
Hi there,
I am also wondering if this is possible since unloading the addin isnt the best solution. Is there any progress on this issue or a good workaround?
all the best,
Tobi
