Ignore vault checkout message in inventor API
basnederveen
Message 1 of 35
basnederveen
Hi everyone,
I was wondering if it was possible to press NO on the 'Do you want to check this item out from Vault?' prompt in an add-in/macro?
Turning on silentoperation does not work for this. I know the commandmanager gives me the option to check-in, out and undo-check-out my files, but I haven't been able to find what I am looking for.
Thanks in advance
Bas
Replies (34)
Message 2 of 35
dgreatice
Have you tried to set Vault Prompt at Vault Option?
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 3 of 35
basnederveen
Hi, thanks for your reply.
The setting I want to change is here 'File edit: File .. is not checked out...', I want to change this in the beginning of my code and change it back in the end. Do you know if this is possible?
Message 4 of 35
bradeneuropeArthur
Maybe this can be done with the edmaddin of inventor?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 5 of 35
basnederveen
What is the edmaddin?
Message 6 of 35
bradeneuropeArthur
This is a dll that should be referenced to.
Imports Connectivity.InventorAddin.EdmAddin
I use vb.net to use the dll reference.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 35
basnederveen
I do not understand. Do do what I am trying to achieve? How can you find what functions you can use from the edm addin? When I find it in VBA i just find the following options
Could you share a bit of the code when you are using this addin ?
Message 8 of 35
bradeneuropeArthur
I will take a look at it if it is possible doing it this way. There must be a possibility I assume. But need to check.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 35
bradeneuropeArthur
I have the solution for you I think.
This is working for me at least:
imports Connectivity.Inventor.Forms
'check to show not show dialog
Connectivity.Inventor.Forms.SuppressCheckInDialog.SuppressSetting = True
Routine from you
'check to show  dialog
Connectivity.Inventor.Forms.SuppressCheckInDialog.SuppressSetting = false
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 35
basnederveen
Ive had a quick look and I found out this surpresses the dialogs - but not the prompts. As soon as i have time I will try finding if the prompt can also be surpressed using this connectivity .dll.
Thanks for pushing me in the right direction i will let you know if it works out
Message 11 of 35
basnederveen
Im looking for the check out on file edit prompt btw
Message 12 of 35
bradeneuropeArthur
Ok succes.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 35
bradeneuropeArthur
I think if we investigate it further there will lso be a possibility to do this I assume.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 35
basnederveen
Still have not found if it is possible to achieve what dgreatice showed through API! Anyone knows if it is possible to change the prompt settings through api?
thanks
Message 15 of 35
dgreatice
Because I only VBA user. I cant install visual studio and access vault reference because admin privilege at my company, sorry I cant help anymore.
Message 16 of 35
bradeneuropeArthur
You could also use Xlm serialization.
because the settings are all stored in an xml file.
hope this helps.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 35
dgreatice
I don't know how to use xml serialization. I new at API, can you teach me about XML serialization? maybe reference document.
I will learn my self.
Message 18 of 35
basnederveen
I have found the XML file containing the settings! Gonna try working with this. Will let you know if it works out! Thanks!
....\AppData\Roaming\Autodesk\Inventor 2018 Vault Addin
 <Category ID="VDFPrompts">
    <Property Name="CheckOutOnFileEdit_PromptInstruction" Value="PromptAlways" />
    <Property Name="CheckInSave_PromptInstruction" Value="PromptAlways" />
    <Property Name="CheckInOnClose_PromptInstruction" Value="PromptAlways" />
    <Property Name="IDS_FILEDIFF_WARN_PromptInstruction" Value="PromptAlways" />
    <Property Name="DownloadConfirmReplaceCheckedOut_PromptInstruction" Value="PromptAlways" />
    <Property Name="DownloadConfirmReplaceLocalEdits_PromptInstruction" Value="PromptAlways" />
    <Property Name="OpenFromVaultNotCheckedOut_PromptInstruction" Value="PromptAlways" />
    <Property Name="IDS_ONRESOLVEFROMVAULT_PromptInstruction" Value="PromptAlways" />
    <Property Name="IDS_CHECKOUT_OTHER_WARN_PromptInstruction" Value="PromptAlways" />
    <Property Name="DownloadConfirmReplaceCheckedOut_UserAnswer" Value="Yes" />
    <Property Name="CheckInSave_UserAnswer" Value="Yes" />
    <Property Name="GetOlderVersion_UserAnswer" Value="YesToAll" />
    <Property Name="GetOlderVersion_PromptInstruction" Value="PromptAlways" />
    <Property Name="OpenFromVaultNotCheckedOut_UserAnswer" Value="No" />
    <Property Name="DownloadConfirmReplaceLocalEdits_UserAnswer" Value="YesToAll" />
    <Property Name="CheckInOnClose_UserAnswer" Value="Yes" />
    <Property Name="IDS_ONRESOLVEFROMVAULT_UserAnswer" Value="Yes" />
    <Property Name="CheckOutOnFileEdit_UserAnswer" Value="Yes" />
    <Property Name="IDS_CHECKOUT_LOCKED_WARN_UserAnswer" Value="Yes" />
    <Property Name="IDS_CHECKOUT_LOCKED_WARN_PromptInstruction" Value="PromptAlways" />
    <Property Name="IDS_CHECKOUT_OTHER_WARN_UserAnswer" Value="Yes" />
    <Property Name="IDS_READONLY_WARN_UserAnswer" Value="Yes" />
    <Property Name="IDS_READONLY_WARN_PromptInstruction" Value="PromptAlways" />
    <Property Name="IDS_CHECKOUT_LOCATION_WARN_UserAnswer" Value="Yes" />
    <Property Name="IDS_CHECKOUT_LOCATION_WARN_PromptInstruction" Value="PromptAlways" />
    <Property Name="IDS_FILEDIFF_WARN_UserAnswer" Value="Yes" />
  </Category>
Message 19 of 35
bradeneuropeArthur
You can change the file with xml serialization.
Or simple with text writer.
Change the xml file as wanted with text writer.
Than change it back with text writer.
Or with serialization of course.
Hope it will succeed!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 20 of 35
basnederveen
Hi
To start this off I thought I'd try editing the settings in the xml file while inventor is running, and see if it also reads the settings from there, but it looks like Inventor just writes the settings after changing. So by just editing the XML I need a restart of inventor to have the new settings go into effect.
Then I thought to try reloading the addin - this creates a new 'clean' xml file on reloading the addin.
So this would mean I need to have the vault addin read the settings from the xml file while inventor is running?  Is this even possible?
While writing this I just realised it might work to unload the vault addin -> do the stuff i want to do -> enable the addin
Still interested in knowing more about these XML settings though, I have a feeling editing those while inventor is running can be handy in alot of situations!
