Batch Saving model to IDW or inventor dwg
tracey
tracey
I have used this code to successfully to create rules to batch save step files and dwg files (AutoCAD) but I really want inventor dwg's .  I have simply changed out .stp to .dwg which has worked but if I do .idw I get a parameter error.
Format:HTML Format
Version:1.0
StartHTML: 165
EndHTML: 26203
StartFragment: 314
EndFragment: 26171
StartSelection: 314
EndSelection: 314
SyntaxEditor Code Snippet
 'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = ThisDoc.FileName(False) 'without extension
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "Batch DRAWING File Creation")
Exit Sub
'get user input
RUsure = MessageBox.Show ( _
"This will create a DRAWING file for all components." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DRAWING file for all of the assembly components?" _
& vbLf & "This could take a while.", "Confirm - Batch DRAWING File Creation ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
'- - - - - - - - - - - - -STEP setup - - - - - - - - - - - -
oPath = ThisDoc.Path
'get DRAWING target folder path
oFolder = oPath & "\DRAWING FILES\"
'Check for the drawing folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
'- - - - - - - - - - - - -Assembly Export- - - - - - - - - - - -
oTime = Now.ToString("HH:mm:ss")
ThisDoc.Document.SaveAs(oFolder & oAsmName & (".idw"), True)
'- - - - - - - - - - - - -Components - - - - - - - - - - - -
look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the referenced models
For Each oRefDoc In oRefDocs
Dim oCurFile As Document
oCurFile = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
oCurFileName = oCurFile.FullFileName
If oRefDoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kNormalBOMStructure Then
'defines backslash As the subdirectory separator
Dim strCharSep As String = System.IO.Path.DirectorySeparatorChar
'find the postion of the last backslash in the path
FNamePos = InStrRev(oCurFileName, "\", -1)
'get the file name with the file extension
Name = Right(oCurFileName, Len(oCurFileName) - FNamePos)
'get the file name (without extension)
ShortName = Left(Name, Len(Name) - 4)
Try
oCurFile.SaveAs(oFolder & ShortName & ("idw") , True)
Catch
MessageBox.Show("Error processing " & oCurFileName, "DRAWING File Creation Error")
End Try
oCurFile.Close
Next
MessageBox.Show("New Files Created in: " & vbLf & oFolder, "Batch DRAWING File Creation")
'open the folder where the new files are saved
Shell("explorer.exe " & oFolder,vbNormalFocus)
Is there a way of specifying?
Many thanks
Tracey P
(Thnk you to the creator of this code by the way.  I don't know who you are but found the code from someone who also used it.)
MechMachineMan
The inventor dwg's have their own save method via the API.
See the attached resource:
(specifically .SaveAsInventorDwg)
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-902B2746-25C9-41A6-953E-C22C28C880AE
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
tracey
Thanks Justin,   I realise that I can't use save as to create and IDW or inventor DWG.  So can I use the API string in
iLogic?   I get the following error :
Error on Line 31 : Comma, ')', or a valid expression continuation expected.  (snapshot below)  Don't know what it is asking for.
I can use iLogic quite well but this is beyond my skills at the moment.  (Looking for a good VB course!)
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 4281 StartFragment: 314 EndFragment: 4249 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
ThisDoc.Document.DrawingDocument.SaveAsInventorDWG ( FullFileName As String SaveCopyAs As Boolean (True))
'- - - - - - - - - - - - -Components - - - - - - - - - - - -'look at the files referenced by the assembly
  Regards
Tracey
MechMachineMan
From API:
SaveAsInventorDWG ( FullFileName As String, SaveCopyAs As Boolean (True))
Your code:
How I would do it:
SaveAsInventorDWG (FullFileName, SaveCopyAs)
 but with the appropriate variables. The error stack really is plain english...
Justin K
tracey
I now get another error that I don't understand:
Reference to a non-shared member requires an object reference...
problem is - I don't know what that means, or is!!
(Getting closer to the code working and reading/learning loads - must stay positive!)
DrawingDocument.SaveAsInventorDWG ( ThisDoc.FileName(False), SaveCopyAs)
 Kind regards and thank you for your help
Tracey
