iLogic switch components in a pattern
Ted.F
Ted.F
 So, this is my first post in the forum so bare with me.
Goal: Swap out (all) parts in a pattern based on a selection (user parameter)
Issue: When selecting options it does not update correctly
What works: Option 1- Select width 06, 09, 12, 15, 18 etc. Option 2- Select part type wood, uhmw
If I make a selection in option 2 I have to change Option 1 to a choice that is a qty of 1, then make a selection that has a larger qty. and it all works fine.
Pattern has both wood wearstrip and uhmw wearstrip selected as components and I toggle back and forth.
Not sure what I am missing and ANY help would be appreciated.
SyntaxEditor Code Snippet
'Select wearstrip style then pattern
                If Wearstrip_Style = "WOOD" Then
                    Component.IsActive("Wood Wearstrip")= True
                    Component.IsActive("UHMW Wearstrip")= False
                ElseIf Wearstrip_Style = "UHMW" Then
                    Component.IsActive("UHMW Wearstrip")= True
                    Component.IsActive("Wood Wearstrip")= False
        Parameter.UpdateAfterChange=True
    If Chain_Width = "06 in" Then
        Parameter("Carryway_Wearstrip") = 1
        Parameter("Return_Wearstrip_Spacing") = 2.625
        Parameter("Return_Wearstrip_Qty") = 2
    ElseIf Chain_Width = "09 in" Then
        Parameter("Return_Wearstrip_Spacing") = 4.125
    ElseIf Chain_Width = "12 in" Then
        Parameter("Return_Wearstrip_Spacing") = 5.625
    ElseIf Chain_Width = "15 in" Then
        Parameter("Carryway_Wearstrip") = 2
        Parameter("Return_Wearstrip_Spacing") = 7.125
    ElseIf Chain_Width = "18 in" Then
        Parameter("Carryway_Wearstrip") = 3
        Parameter("Return_Wearstrip_Spacing") = 4.3125
        Parameter("Return_Wearstrip_Qty") = 3
Hi Ted_fNRXGQ,
just try this code snippet at the end of the rule!
    'Updating the document
    InventorVb.DocumentUpdate()
Ted.F
Armin,
  Thanks for the response. I actually have that in the bottom of the code. It cut off my code when I posted.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Ted.F,
In Inventor 2018, new level of details is required to modify / suppress component in an assembly as shown below.
A sample assembly is created to test and attached with this post. Below iLogic rule is created to test suppression of patterns.
Component.IsActive("Wood Wearstrip:1") = False
Component.IsActive("UHMW Wearstrip:1") = False
Component.IsActive("Component Pattern 1:1") = False
Component.IsActive("Component Pattern 2:1")= False
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Ted.F
Chandra,
  Thank you for the response. I am already using LOD and suppression for some other parts. However, I do not think it would be an efficient way to address this assembly. Everything works great, except the regeneration of that pattern.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Ted.F,
Regeneration of patterns is working fine on running following iLogic code
Component.IsActive("Component Pattern 1:1") = True
Component.IsActive("Component Pattern 2:1")= True
Can you please provide assembly and associated files to test? mention Inventor versions also.
Please make sure that files are non confidential one.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
