iFeature
iFeature
martinhoos
Message 1 of 20
iFeature
martinhoos
i have a iFeature named LongPilot. If i insert this one time the name changed to "LongPilot:1" and the next time to "LongPilot:2". Is it possible to count the quantity of the "LongPilots"?  Possible quantitys are only:  0 or 1 or 2 of them. The amount stored in an userparameter named "amount".
One Probleme: If i insert and insert and delete and delete the Longpilots, i can have names like "LongPilot:8" or stuff like this....
Hopefully you can help me...
Regards from Germany.
Martin
Replies (19)
Message 2 of 20
bradeneuropeArthur
Again and modified a little!!
Public Sub features()
Dim a As Application
Set a = ThisApplication
Dim b As PartDocument
Set b = a.ActiveDocument
Dim f As Object ' ExtrudeFeature
'Set c = b.ComponentDefinition.Features
Dim i As Integer
i = 0
For Each f In b.ComponentDefinition.features
If InStr(f.Name, "LongPilot") > 0 Then
i = i + 1
End If
Next
MsgBox i
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 20
martinhoos
Hi Brandeneurope,
thank you for your reply... your makro runs! Is it possible for you to change the script into ilogic-code? I tried .... without result  😞
Regards Martin
Message 4 of 20
chandra.shekar.g
Autodesk Support
Autodesk Support
@martinhoos,
Try the following iLogic code to count LongPilot iFeature.
b = ThisApplication.ActiveDocument
Dim i As Integer
For Each f In b.ComponentDefinition.Features
	If f.Name.StartsWith("LongPilot")Then
		i = i + 1
	End If
Next
MessageBox.Show("Count of LongPilot is : " & i.ToString, "iLogic")
Please feel free to contact if there is any queries,
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 5 of 20
bradeneuropeArthur
Yes,
Public Sub Main()
a = ThisApplication
Dim i As Integer
i = 0
i = i + 1
End If
Next
MsgBox (i)
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 20
bradeneuropeArthur
@martinhoos
Please let me know if you need further assistance....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 20
martinhoos
Hi Brandeneurope,
yes i need further help.... i thought i couldt handle this by myselfe - but ..... (its to hard to understand)
the idea is: i have a tube which i changed which ilogic (diameter, radius, material ....)
sometimes i need the "LongPilot", which has also a diameter. If the Name of the LongPilot is "LongPilot:1" or "LongPilot:2" i can change the diameter with:
iFeature.ChangeRow("LongPilot:1", "16 mm")
or
iFeature.ChangeRow("LongPilot:1", "18 mm")
But sometimes the name is, for example like, "LongPilot:5"  (delete and stored again) - so i can not identify the Name   😞
I used this code to place the LongPilot in:
Public Sub Main()
	Dim oPartDoc As PartDocument
	oPartDoc = ThisApplication.ActiveDocument
	Dim oPartDef As PartComponentDefinition
	oPartDef = oPartDoc.ComponentDefinition
	Dim oWorkPoint As WorkPoint
	oWorkPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPointFilter, "Select a point to place iFeature")
	' Get the selected face to use as input for the iFeature.
	Dim oFacePlane As WorkPlane
	oFacePlane = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPlaneFilter, "Select a Plane to place iFeature")
	Dim oFeatures As PartFeatures
	oFeatures = oPartDef.Features
	' Create an iFeatureDefinition object.
	Dim oiFeatureDef As iFeatureDefinition
	oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition("V:\Inventor-2015\1-Inventor\Catalog\KKI\LongPilot.ide")
	' Set the input.
	Dim oInput As iFeatureInput
	For Each oInput In oiFeatureDef.iFeatureInputs
		Dim oParamInput As iFeatureParameterInput
		Select Case oInput.Name
		Case "Durchmesser"
		Dim oTubeDia As iFeatureParameterInput
		oTubeDia = oInput
		oTubeDia.Expression = durchmesser
		Case "Skizzierebene1"
		Dim oPlaneInput As iFeatureSketchPlaneInput
		oPlaneInput = oInput
		oPlaneInput.PlaneInput = oFacePlane
		Case "Referenzpunkt1"
		Dim oRefPoint As iFeatureEntityInput
		oRefPoint = oInput
		oRefPoint.Entity = oWorkPoint
		End Select
	Next
	' Create the iFeature.
	Dim oiFeature As iFeature
	oiFeature = oFeatures.iFeatures.Add(oiFeatureDef)
End Sub
Long Story short: If i changed the diameter from the tube all longpilots (max. 2) shouldt change also....  AND i need the amount of the Longpilots (you gave me the code above)
Hopefully you can give me support to handle the problem.... Thank you very much!
Regards
Martin
Message 8 of 20
bradeneuropeArthur
So if Diameter pipe change from 12 mm to 16 mm, the Pilot must also change from 12 to 16 mm. am I right?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 20
chandra.shekar.g
Autodesk Support
Autodesk Support
@martinhoos,
Do you need number of 16 dia tube and 12 dia tube? Also, wants to change name of LongPilot to respective diameter name?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 10 of 20
martinhoos
yes you are right....
Message 11 of 20
martinhoos
The Diameters are Ø10, Ø12, Ø16 and Ø18
If i changed the Diameter from Ø12 to Ø18 of the tube, the Longpilot shouldt also changes to Ø18.
The second is, i need the number of inserted LongPilots (0 or 1 or 2)
Regards Martin
Message 12 of 20
bradeneuropeArthur
Could you please upload the feature PilotHole
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 20
martinhoos
Hello Brandeneurope,
thanks for your reply... here is the iFeature...
Regards Martin
Message 14 of 20
bradeneuropeArthur
How is your pipe diameter parameter called?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 20
martinhoos
the Diameter of the pipe is called: durchmesser
Message 16 of 20
bradeneuropeArthur
Public Sub Main()
MsgBox 	 (Parameter.Param("durchmesser").expression)
If Parameter.Param("durchmesser").Expression = "10 mm
Call features("LongPilot", 10 mm) End If
If Parameter.Param("durchmesser").Expression = "16 mm" Then
16 mm)
End If
'etc
End Sub Public Sub features(Str As String , Dia as string) Dim a As Application a = ThisApplication Dim b As PartDocument b = a.ActiveDocument Dim f As Object ' ExtrudeFeature 'Set c = b.ComponentDefinition.Features Dim i As Integer i = 0 For Each f In b.ComponentDefinition.Features If InStr(f.Name, Str) > 0 Then iFeature.ChangeRow(f.name, Dia) i = i + 1 End If Next MsgBox (f.name) MsgBox (i) End Sub
 EDIT .....................
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 20
chandra.shekar.g
Autodesk Support
Autodesk Support
@martinhoos,
Try the following iLogic code to rename the "LongPilot" iFeature with respect to Diameter.
Public Sub Main()
    Dim i10Cnt As Integer
    Dim i12Cnt As Integer
    Dim i16Cnt As Integer
    Dim i18Cnt As Integer
    For Each oiFeature In oFeatures.iFeatures
        If InStr(oiFeature.Name, "LongPilot") > 0 Then
            If oiFeature.Parameters.Item(8).Expression = "10 mm" Then
                i10Cnt = i10Cnt + 1
            ElseIf oiFeature.Parameters.Item(8).Expression = "12 mm" Then
                i12Cnt = i12Cnt + 1
            ElseIf oiFeature.Parameters.Item(8).Expression = "16 mm" Then
                i16Cnt = i16Cnt + 1
            ElseIf oiFeature.Parameters.Item(8).Expression = "18 mm" Then
                i18Cnt = i18Cnt + 1
            End If
        End If
    Next
    Dim i As Integer
    If i10Cnt > 0 Then
        For i = 1 To i10Cnt
                        If oiFeature.Name = "LongPilot Dia 10 mm :" & i - 1 Then
                             GoTo NextIteration10
                        End If
                        If Not InStr(oiFeature.Name, "LongPilot Dia 10 mm :") > 0 Then
                            oiFeature.Name = "LongPilot Dia 10 mm :" & i-1
                        End If
                    End If
                End If
            Next
NextIteration10:
        Next
    End If
    If i12Cnt > 0 Then
        For i = 1 To i12Cnt
                        If oiFeature.Name = "LongPilot Dia 12 mm :" & i -1 Then
                             GoTo NextIteration12
                        End If
                        If Not InStr(oiFeature.Name, "LongPilot Dia 12 mm :") > 0 Then
                        End If
                    End If
                End If
            Next
NextIteration12:
        Next
    End If
    If i16Cnt > 0 Then
        For i = 1 To i16Cnt
                        If oiFeature.Name = "LongPilot Dia 16 mm :" & i -1Then
                             GoTo NextIteration16
                        End If
                        If Not InStr(oiFeature.Name, "LongPilot Dia 16 mm :") > 0 Then
                        End If
                    End If
                End If
            Next
NextIteration16:
        Next
    End If
    If i18Cnt > 0 Then
        For i = 1 To i18Cnt
                        If oiFeature.Name = "LongPilot Dia 18 mm :" & i - 1 Then
                             GoTo NextIteration18
                        End If
                        If Not InStr(oiFeature.Name, "LongPilot Dia 18 mm :") > 0 Then
                        End If
                    End If
                End If
            Next
NextIteration18:
        Next
    End If
End Sub
Please feel free to contact if there is any queries.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 18 of 20
bradeneuropeArthur
Please let me know if you need assistance.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 19 of 20
martinhoos
Thank you very much ... this is what i needed!  Great work.
Regards Martin
Message 20 of 20
martinhoos
Hello Chandra,
thank you very much for your help - also your code helps me to solve my Problem.
Regards Martin
