Transparent background
Message 1 of 17
I'm looking for a way to export images with a transparent background using iLogic. Is it possible?
Replies (16)
Message 2 of 17
bradeneuropeArthur
This will do:
Public Sub SaveAsJPG()
    ' Get the active view.
    Dim oView As View
    Set oView = ThisApplication.ActiveView
 'Create a new NameValueMap Object
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap '.TransientObjects.CreateNameValueMap
    oOptions.Value("TransparentBackground") = True
    Call oView.SaveAsBitmapWithOptions("C:\Temp\TestB.bmp", 0, 0, oOptions)
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 17
Thank you for your reply but I'm working on Inventor 2015 and it doesn't seems to work.
I've got a run-time error '438'
Object doesn't support this property or method...
Message 4 of 17
bradeneuropeArthur
Could you please make the same screenshot as me:
I am using 2018 inventor.
let us check the difference.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 17
Message 6 of 17
Message 7 of 17
bradeneuropeArthur
The same screenshot please, if you select BMP files!!
Seems that this option is not available for 2015 of inventor!!!!
What would you like to do with the Picture?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 17
We give our client a view of what they've bought to permitt them to place it on a photo...
I also tried to do this with Inventor Studio.
It is possible but the problem is to set the Inventor Studio's camera's position.
I'd like to make it fit to the current view with iLogic or Vba... Is it possible ?
Message 9 of 17
bradeneuropeArthur
Why must it be transparent than?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 17
Is there a way to export a picture of an Inventor assembly without background ?
Message 11 of 17
bradeneuropeArthur
You could remove the background in "Word"
https://www.youtube.com/watch?v=qTGdFP8gRVs
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 17
Sorry for my English but is there a sample to do this in Inventor using Word Application.
I already export parameter from Inventor to word with this method.
'Create the Word Application Object
wordApp = Interaction.CreateObject("Word.Application")
Message 13 of 17
bradeneuropeArthur
        Dim myBitmap As New Bitmap("C:\TEMP\ForumTestsVba.bmp")
        myBitmap.MakeTransparent()
        myBitmap.Save("C:\TEMP\ForumTestsVba2.bmp")
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 17
Thank for your quick replies but I've tried your code in the iLogic module and in Vba module but doesn't seem to work...
 The 'Bitmap' Type is not defined....
Another way to do what I want, would be to launch the command in the picture attached.
Is it possible to use iLogic or Vba to define Camera on Current View in Inventor Studio?
Message 15 of 17
I'd like to thank you for all.
Finally, I've found another way to do.
Message 16 of 17
bradeneuropeArthur
Now I am curious, how did you do it?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 17
I'm using the interop.InventorStudioLib.dll as shown in this link
https://forums.autodesk.com/t5/inventor-customization/how-do-i-access-inventor-studio-elements/td-p/...
I only have to render manually with options a first time in Inventor Studio and then, when I launch the iLogic rule, as parameters are saved, I don't need to precise them again.
It's not really professionnal but it works  😉
Thanks again for your quick replies.
