idw custom iproperties
andrew_canfield
Message 1 of 9
andrew_canfield
Hello
How would you start to tackle this?
Select a list of idw's,
(I've seen this code in the past)
  GetFilenames = Split(oFileDlg.FileName, "|") ' if multiple names were selected, they will be separated by vertical bar characters
 After selection I'd like to display the custom iproperties & edit them - just the drawing idw iproperties.
Most of the code I've found so far requires the drawing to be open - can this be done without opening the drawing?
(some drawings can take a while to open, just think it would be quicker drilling straight to the custom iproperties - not sure how to enter the path to the iproperties of a file on the disk.)
Thinking along the lines of:
Happy to start with something simple if possible.
Regards
Andrew
Replies (8)
Message 2 of 9
bradeneuropeArthur
why don't you use design assistant for this?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
matt_jlt
I think  you are after Inventor Apprentice. It lets you access a limited amount of file information such as properties etc.
Some good reference info is below + i would look at the inventor API help documentation for the API, it has some good information and examples in there aswell.
https://adndevblog.typepad.com/manufacturing/2012/11/using-inventor-properties-from-apprentice-serve...
https://modthemachine.typepad.com/my_weblog/2010/03/iproperties-without-inventor-apprentice.html
Matt.
Message 4 of 9
andrew_canfield
Thanks for the suggestion but DA only opens one file at once.
The issue is projects being modified - the customer asks for their reference to be changed (custom iprop) - open, edit & close 50 .idw's
Would be nice to see the properties laid out in a table too.
Regards
Andrew
Message 5 of 9
bradeneuropeArthur
Design Assistant can open multiple files at once!
  • Open folder in Design Assistant.
  • In file explorer select multiple and RMB (Right Mouse Button) open Design Assistant.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 9
andrew_canfield
Thanks again, multiple files do open - just can't access the (custom) properties :
Needed to type the custom property in (hoping to have this set for repeat edits)
& the column to edit the properties can't be customized (or it looks that way) in 'Manage':
If the the custom iproperties could be fixed & edited in this 'Manage' window - perfect.
Message 7 of 9
bradeneuropeArthur
Of course you can..
Select the Multiple files in Design Assistant and then RMB I-properties...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 9
andrew_canfield
nothing opens after pressing open... is there a different open?
Message 9 of 9
andrew_canfield
ok it does work - but it's very clicky.
Right Click iproperties
custom
scroll
edit
modify
ok
 - to click in the cell & edit would be great - if possible.
