iLogic: Export to PDF + Print (2D Enviroment)
I'm asking for 2 codes
1) Export to PDF, same function as File > Export > PDF ...However, if this could include a subfix from a fx selectable parameter, that would be really cool
2) Print, same function as File > Print > Print
Sergio.D.Suárez
Hi, This is an example of code that I usually use to print a drawing document with many sheets.
oDoc = ThisDoc.Document
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
For Each oSheet In oDoc.Sheets
oSheet.Activate
If oSheet.ExcludeFromPrinting = False Then
oPrintMgr = oDoc.PrintManager
oPrintMgr.ColorMode = 13315    'kPrintGrayScale -> 13314 _kPrintDefaultColorMode ->13315
oPrintMgr.NumberOfCopies = 1
oPrintMgr.PaperSize = 14341   'kPaperSizeCustom
oPrintMgr.Scalemode = 13825  'Full Scale mode
	If oSheet.Orientation = 10243 Then
	oPrintMgr.Rotate90Degrees = False
	Else
		oPrintMgr.Rotate90Degrees = True
oPrintMgr.PrintRange = kPrintCurrentSheet
oPrintMgr.SubmitPrint
Next
 I hope it is useful for you. Best Regards!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
I'd like to enter the "Print Drawing" menu like I normally would
bradeneuropeArthur
Then you need to change your commandbutton and replace it with your "Custom" one.
This can be done within an add-in.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
