Event Triggers Iproperties change on single iproperties
Darkforce_the_ilogic_guy
Advisor Advisor
Message 1 of 10
I would like to know if it is possible  to  make an event triggers  with a special Iproperties are change.
I want to run a code when Surface is change .. it is a custom properties I iproperty.... but I do not want it to run ever times that someone make a change to any other iproperties.
how can I do this ?
Replies (9)
Message 2 of 10
bradeneuropeArthur
Sub AddHandlers()
    Dim oDoc As Inventor.Document = invApp.ActiveDocument
    AddHandler oDoc.DocumentEvents.OnChange, AddressOf Me.ChangeSub
End Sub
Sub ChangeSub(ReasonsForChange As CommandTypesEnum, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, HandlingCode As HandlingCodeEnum)
    If ReasonsForChange = CommandTypeEnum.kFilePropertyEditCmdType Then
          ' Do something cool
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 10
do not understand how it work .. are there not missing somthing ?
Message 4 of 10
in VBA?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 10
ilogic
Message 6 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
@Darkforce_the_ilogic_guy,
There is a in built event trigger is available in Inventor 2020.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 7 of 10
There is already a build in trigger for iproperties , but is there a way to limit the change I need only to happen when I change iproperties.Custom.Surface ?
Message 8 of 10
the best I can do so far is to use the the Event Trigger IproPerties change
then Writte this code
Dim doc = ThisDoc.Document
	Dim sDocumentSubType As String = doc.SubType
'Undersøger Document type"
	If sDocumentSubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Or sDocumentSubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}"  Or sDocumentSubType = "{E60F81E1-49B3-11D0-93C3-7E0706000000}" Or sDocumentSubType = "{28EC8354-9024-440F-A8A2-0E0E55D635B0}" Then ' = "assembly"Then	' = "Sheet Metal"
If iProperties.Value("Custom", "Surface") ="Colour 1" Or iProperties.Value("Custom", "Surface") ="Colour 2" Or iProperties.Value("Custom", "Surface") ="RAL 1028"Or iProperties.Value("Custom", "Surface") ="RAL 5003" Or iProperties.Value("Custom", "Surface") ="RAL 7035"Or iProperties.Value("Custom", "Surface") ="RAL 7037"Or iProperties.Value("Custom", "Surface") ="RAL 9005"Or iProperties.Value("Custom", "Surface") ="RAL 9010" Or iProperties.Value("Custom", "Surface") ="EG-Galv" Or iProperties.Value("Custom", "Surface") ="HDG-Galv"
iLogicVb.RunExternalRule("RefreshColour")
but it still  run the code if I do any change to iproperties , but I only want it to run when there has been a chance to iProperties.Value("Custom", "Surface")
I am using inventor 2018 ... can I use iproperties on All Document in inventor 2020 ?... I can only do it local on the fil in 2018 :S
Message 9 of 10
MjDeck
The iLogic iProperty Change event is not available on All Documents in Inventor 2020. It is still only in This Document. However, we can make it available on All Documents in a future version.
It looks like there is no way to find out which property has changed using the API.
Mike Deck
Software Developer
Autodesk, Inc.
Message 10 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
Can you please log a wish list on this at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards
CHANDRA SHEKAR G
Developer Advocate
