how to replace Model Reference in .idw file.
how to replace a ipt or iam in an inventor drawing via vb?
Thanks, best regards
Massimo
pball
Here is the basic code to replace a drawing view. This will replace the first drawing view with part.ipt. Post back if you have any more questions.
Dim oDocument As Document
Set oDocument = ThisApplication.ActiveDocument
oDocument.File.ReferencedFileDescriptors.Item(1).ReplaceReference("c:\part.ipt")
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
MechMachineMan
* Not necessarily first drawing view.
If BOM was placed before drawing views, it will replace the BOM reference.
Model references are generally easier to replace using the UI functionality, but can be done through API using pball's method as well.
Sub Test()
    Call ReplaceFileReference(ThisDoc.Document, "C:\PartA.ipt", "C:\PartB.ipt")
End Sub
Sub ReplaceFileReference(oDoc as Document, oRefToRemove As String, oRefToInclude As String)
    For Each oFD In oDoc.File.ReferencedFileDescriptors
        If oFD.FullFileName = oRefToRemove
             oFD.ReplaceReference(oRefToInclude)
        End if
    Next
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
