remove pic in material appearance
^_^clovis^_^
^_^clovis^_^
I'm trying to remove the image in the default material used when importing a Step file. But I can't find a solution.
If someone has an idee please share it with me. I'm trying at first in part and scale it later to assembly.
 Dim invDoc As Document
    Set invDoc = ThisApplication.ActiveDocument
    If invDoc.DocumentType = kPartDocumentObject Then
        'create object color/look
        Dim oAsset As Asset
        Dim oLib As AssetLibrary: Set oLib = ThisApplication.AssetLibraries("Autodesk Appearance Library")
        Set oAsset = oLib.AppearanceAssets("Generic")
        Dim pcd As PartComponentDefinition
        Set pcd = invDoc.ComponentDefinition
           invDoc.ActiveAppearance = oAsset
        'Next
^_^clovis^_^
I forgot to mention, I'm using Inventor 2017 pro.
It seems to be a known problem as it is already mentioned hier.
Is there a fix somewhere?
^_^clovis^_^
thanks to Saseendrankom I've solved my problem to remove a link used in appearance.
kind of.
Sub AssetTextureSample()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oAppearance As Asset
    For Each oAppearance In oDoc.Assets
        Dim oValue As AssetValue
        For Each oValue In oAppearance
         'Set oValue = oAppearance.Item(13)
            If oValue.Name = "generic_bump_map" Then
                Dim oColorValue As ColorAssetValue
                Set oColorValue = oValue
                oColorValue.HasConnectedTexture = False
                oDoc.update
        Next
    Next
End Sub
