Editing sketches in parts while in assembly
fakeru
fakeru
Hi all,
So I'm trying to edit a 3D spline in 3D sketch from a part while in assembly context.
The problem is when I select some geometry from other occurrences that I want to use to align my 3D spline, there is no kind conversion between the assembly coordinate system and the part's one. I end up with a displacement equal to displacement between the assembly and part coordinate systems.
I hope I explain this good enough 🙂
Here is my code:
Sub Flexible2()
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim OriginAssy As WorkPoint
Set OriginAssy = oDoc.ComponentDefinition.WorkPoints.Item(1)
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim oPart As ComponentOccurrence
Dim partDoc As Document
Set oPart = ThisApplication.CommandManager.Pick(kAssemblyLeafOccurrenceFilter, "Pick a part")
Set partDoc = oPart.Definition.Document
Dim oPartDef As PartComponentDefinition
Set oPartDef = partDoc.ComponentDefinition
Dim oSketch3D As Sketch3D
Set oSketch3D = oPart.Definition.Sketches3D.Item(1)
Dim oSketch3D2 As Sketch3DProxy
Call oPart.CreateGeometryProxy(oSketch3D, oSketch3D2)
Dim oPointCoords As ObjectCollection
Set oPointCoords = ThisApplication.TransientObjects.CreateObjectCollection()
Dim oEdge As EdgeProxy
Set oEdge = ThisApplication.CommandManager.Pick(kPartEdgeCircularFilter, "Pick the first circular edge")
Dim oEdge2 As EdgeProxy
Set oEdge2 = ThisApplication.CommandManager.Pick(kPartEdgeCircularFilter, "Pick the second circular edge")
Dim Point1 As Point
Set Point1 = oEdge.Geometry.Center
Dim Point2 As SketchPoint3D
Set Point2 = oSketch3D2.SketchPoints3D.Add(Point1)
Dim Point3 As Point
Set Point3 = oEdge2.Geometry.Center
Dim Point4 As SketchPoint3D
Set Point4 = oSketch3D2.SketchPoints3D.Add(Point3)
Dim SketchLine As SketchLine3D
Set SketchLine = oSketch3D.SketchLines3D.Item(2)
Call SketchLine.EndSketchPoint.ConnectTo(Point4)
Dim SketchPath As SketchSpline3D
Set SketchPath = oSketch3D.SketchSplines3D.Item(1)
Call SketchPath.EndSketchPoint.ConnectTo(Point2)
End Sub
Here is an example of what happens:
Any idea how I can fix this?
Autodesk Inventor 2015 Certified Professional
fakeru
no ideas? 😞
