How to read item number as per structured view
abilabib
Message 1 of 22
abilabib
I'm try for read item number like a picture below and wanna get the data structure as per Structured View.
But I can't. Because the program read the ItemNumber as per Model data or Hierarchy in object history.
I wanna the data like this:
1
1.1
1.2
1.3
1.4
1.5
2
2.1
2.2
2.3
3
3.1
3.2
4
5
6
But I get actual data like this :
1
1.1
1.2
1.3
1.4
1.5
4
2
2.1
2.2
2.3
5
6
3
3.1
3.2
Here's the code :
Sub ListBomItems()
        Dim asm As AssemblyDocument
        asm = invApp.ActiveDocument
        Dim b As BOM
        b = asm.ComponentDefinition.BOM
        b.StructuredViewEnabled = True
        Dim bv As BOMView
        bv = b.BOMViews("Structured")
        Call ListItems(bv.BOMRows, 0)
    End Sub
    Sub ListItems(rows As BOMRowsEnumerator, indent As Integer)
        Dim row As BOMRow
        For Each row In rows
            Debug.Print(row.ItemNumber.ToString)
            If Not row.ChildRows Is Nothing Then
                Call ListItems(row.ChildRows, indent + 2)
            End If
        Next
    End Sub
Is there way for rearrange data structure in Model Data / Hierarchy model ?
Replies (21)
Message 2 of 22
martin.jacko
Output looks very interesting.
Could you please provide dataset for investigation?
Martin
Message 3 of 22
abilabib
@martin.jacko
Here's the file.
Message 4 of 22
MechMachineMan
It has been like this forever.
Inventor doesn't internally resort the data based on the item numbering scheme you have set.
The internal order is based on the order in which the documents were added to the assembly (I think).
If you want to get a list by the bom structure, you should just be able to re-sort it by item number afterwords using a custom comparison. Or you could evaluate if you really need the program to do the sorting, and can just get by with some other sort method (ie; excel) afterwards.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 5 of 22
abilabib
@MechMachineMan : Thanks for your reply. Because it's impossible for Numbering component direct from Inventor. So I decide using Excel Spreadsheet in this case.
Afri
Message 6 of 22
chandra.shekar.g
Autodesk Support
Autodesk Support
@abilabib,
I tested provided sample and source code in Inventor 2019 and Visual studio 2017. The results are sorted as shown below. Can you please specify Inventor version that is currently using?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 7 of 22
dgreatice
Hi, this my version. and work for me.
use strcomp argument to find item no. and sort it.
Public Sub OlahDataExport()
    Dim oAPp As Application
    Dim oAD As AssemblyDocument
    Dim oACD As AssemblyComponentDefinition
    Dim oBOM As BOM
    Dim oBOMStructure As BOMView
    Dim oBomRow As BOMRow
    Dim oGetBomRow As BOMRow
    Set oAPp = ThisApplication
    Set oAD = oAPp.ActiveDocument
    Set oACD = oAD.ComponentDefinition
    Set oBOM = oACD.BOM
    On Error Resume Next
    Set oBOMStructure = oBOM.BOMViews.Item("Structured")
    If Err.Number <> 0 Then
        oBOM.StructuredViewEnabled = True
        oBOM.StructuredViewFirstLevelOnly = False
    End If
    oBOMStructure.Sort ("Item")
    For i = 1 To oBOMStructure.BOMRows.Count
        For Each oBomRow In oBOMStructure.BOMRows
            If StrComp(oBomRow.ItemNumber, i, vbTextCompare) = 0 Then
                Set oGetBomRow = oBomRow
                Debug.Print oGetBomRow.ItemNumber
                Call EachChildRowCall(oGetBomRow)
            End If
        Next
    Next
End Sub
Public Sub EachChildRowCall(ByVal oBomRow As BOMRow)
    Dim oChildROw As BOMRow
    Dim oGetChildRow As BOMRow
    For i = 1 To oBomRow.ChildRows.Count
        For Each oChildROw In oBomRow.ChildRows
            If StrComp(Right(oChildROw.ItemNumber, 1), i, vbTextCompare) = 0 Then
                Set oGetChildRow = oChildROw
                Debug.Print oGetChildRow.ItemNumber
                If oGetChildRow.ChildRows Is Nothing Then
                Else
                    Call EachChildRowCall(oGetChildRow)
                End If
            End If
        Next
    Next
End Sub
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 8 of 22
abilabib
@chandra.shekar.g : I'm use Inventor 2015 and VS 2013 Express
Message 9 of 22
chandra.shekar.g
Autodesk Support
Autodesk Support
@abilabib,
There was a change request (INVGEN - 6581) on this. It is fixed in Inventor 2019.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 10 of 22
abilabib
@chandra.shekar.g
Many thanks for your information. But we don't have planning for upgrade to 2019. We still use 2015. Because our head quarter in Canada still use 2015.
Thanks.
Message 11 of 22
YuhanZhang
dgreatice  posted a workaround for this, can you try if it solves the problem?
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 12 of 22
abilabib
It's not working in Inventor 2015 .
Here's the result.
1
1.1
1.2
1.3
1.4
1.5
6
Here's the code
        Dim oBOM As BOM
        oAD = invApp.ActiveDocument
        oBOM = oACD.BOM
        End If
        oBOMStructure.Sort("Item")
                    Debug.Print(oGetBomRow.ItemNumber)
                End If
            Next
        Next
    End Sub
                    Debug.Print(oGetChildRow.ItemNumber)
                    Else
                    End If
                End If
            Next
        Next
    End Sub
Message 13 of 22
YuhanZhang
I have not an Inventor 2015 build at hand, but tested with Inventor 2016 and it prints the right result. Can you debug the code to check why it ignored the ItemNumber from 2 to 5? Also please check that in your data the ItemNumber is not overridden.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 14 of 22
chandra.shekar.g
Autodesk Support
Autodesk Support
@abilabib,
Hoping that below sorting code would help to sort items of Structured view.
Sub ListBomItems()
        Dim b As BOM
        Dim bv As BOMView
        Dim oSort As Dictionary(Of Integer, Integer)
        oSort = BOM_Sort(bv.BOMRows)
        Call ListItems(bv.BOMRows, 0, oSort)
    End Sub
    Function BOM_Sort(rows As BOMRowsEnumerator)
        Dim oSort As Dictionary(Of Integer, Integer) = New Dictionary(Of Integer, Integer)
        Dim oRow As BOMRow
        For i As Integer = 1 To rows.Count Step 1
            oRow = rows.Item(i)
            oSort.Add(oRow.ItemNumber, i)
        Next
        BOM_Sort = oSort
    End Function
    Sub ListItems(rows As BOMRowsEnumerator, indent As Integer, oSort As Dictionary(Of Integer, Integer))
        Dim row As BOMRow
        Dim i As Integer
        For i = 1 To rows.Count Step 1
            Dim key As Integer = oSort(i)
            row = rows.Item(key)
            End If
        Next
    End Sub
        Dim row As BOMRow
            End If
        Next
    End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 15 of 22
abilabib
@chandra.shekar.g : Many thanks for your code. I'll try.
Message 16 of 22
chandra.shekar.g
Autodesk Support
Autodesk Support
@abilabib,
If solves problem, click on "Accept as solution" / give a "Like".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 17 of 22
abilabib
But there's like jumping in looping system. Because some component type can't be read.
Message 18 of 22
chandra.shekar.g
Autodesk Support
Autodesk Support
@abilabib,
Below highlighted (red in color) was missing in previous code.
Sub ListBomItems()
        Dim b As BOM
        Dim bv As BOMView
    End Sub
        Dim oRow As BOMRow
            oRow = rows.Item(i)
        Next
        BOM_Sort = oSort
    End Function
        Dim row As BOMRow
        Dim i As Integer
            Dim oCompDef As ComponentDefinition
            oCompDef = row.ComponentDefinitions.Item(1)
            Debug.Print(row.ItemNumber.ToString & " " & oCompDef.Type.ToString)
            End If
        Next
    End Sub
        Dim row As BOMRow
            End If
        Next
    End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 19 of 22
abilabib
Dear @chandra.shekar.g :
Many thanks for your code and effort.
Case Closed.
Message 20 of 22
abilabib
@chandra.shekar.g. Many thanks for your code. My program is done Smiley Happy.
