How to know Specific Object After Using kAllEntitiesFilter
dgreatice
dgreatice
Hi expert,
Can help me for find, how to know the selected object is a specific filter object, I am also confused how to make this question understandable. in this code I want to specify, whether the object I choose is a custom table or partslist table or revision table?
After I know the type of object, there is another code that I have prepared.
I have trouble knowing how to know what object, when using (kAllEntitiesFilter).
I vba macro in Inventor 2014.
Dim oDwgDoc As DrawingDocument
Set oDwgDoc = ThisApplication.ActiveDocument
Public Sub ChooseTableToEdit()
Dim oSheet As Sheet
Set oSheet = oDwgDoc.ActiveSheet
Dim CMDMan As CommandManager
Set CMDMan = ThisApplication.CommandManager
Dim TableObj As Object
Set TableObj = CMDMan.Pick(kAllEntitiesFilter, "Select any table")
If TableObj = kDrawingCustomTableFilter Then
    MsgBox ("You want edit Custom table Table?")
    'Next my code
ElseIf TableObj = kDrawingPartsListFilter Then
    MsgBox ("You want to edit Part List Table?")
    'Next my code
ElseIf TableObj = kDrawingRevisionTableFilter Then
    MsgBox ("You want to edit Revision Table?")
    'Next my code
End Sub
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
MechMachineMan
You can't figure out what filter it was selected with as the Pick Method returns the object
Instead you need to use the SelectedObject.TYPE property to find the type of the object you selected.
It should return a number/enum that corresponds with inventor's ObjectTypeEnum.
If the object returns as kGenericObject, I believe that means you are out of luck.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
dgreatice
did you mean like this?, can you help me with sample from my code. The red text was still error, because i dont know to set ObjectTypeEnum to specific class.
Dim oSheet As Sheet
Dim oCusTab As CustomTable
Dim oPartList As PartsList
Dim oRevTab As RevisionTable
If TableObj.Type = 117461248 Then
    Set oCustTab = TableObj
ElseIf TableObj.Type = 117444096 Then
    set oPartList = TableObj
ElseIf TableObj.Type = 117466624 Then
    set oRevTab = TableObj
End Sub
MechMachineMan
You could still use the same TableObj... you don't need to redefine it. But it should be identifying the proper type of item for you now, right?
Justin K
