Ilogic to open document directory and select the document file
I am using an easy Ilogic rule, which opens the directory of the open document via explorer.exe
If ThisDoc.Path IsNot "" Then
Shell("explorer.exe " & ThisDoc.Path,vbNormalFocus)
Else
MessageBox.Show("Cannot open the file directory", "iLogic")
 But when I have a lot of files in the document directory, its pretty complicated to find the document file. Is there any possibility to make explorer highlight (or select) the used document file? I tried the standard functions for both explorer.exe and VBAs Shell, but it did not work.
Thank you for help!
MechMachineMan
Pretty sure there is.
Since this functionality isn't specific to inventor, 2 better places to look are StackOverflow and MSDN.
Good luck.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thank you, you were right.
It was solved by this post at stackoverflow.com
https://stackoverflow.com/questions/31689802/launching-windows-explorer-and-highlighting-a-file
But you have to write the command after Shell into brackets.
dusan.naus.trz
It took me a little bit then I understood. I give the whole solution to others.
Not only do you have to insert Select as an explorer, but when I used & ThisDoc.PathAndFileName (True) it bothered him in the path (True) it couldn't evaluate it, but true is needed because of the end that defines shortened and it already works
filepath = ThisDoc.PathAndFileName(True)
If filepath IsNot "" Then
Shell("explorer.exe /Select," & filepath, vbNormalFocus)
Else
