How to Inventor DockableWindow Show Tab but not Visible/Activated
bradeneuropeArthur
Mentor Mentor
bradeneuropeArthur
@JelteDeJong  or others
How can I make the "Tab" from my Custom Dockablewindow visible in inventor, I don't want it activated or visible.
I only want it o be shown that it is there in the browser tab.
I know how to use the checkbox in the Window>>User Interface,.
But how do I fix this setting for the next time inventor opens.
Is there any option "Show visible in Browser" or something in the API?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Think I already found the answer:
You don't need to set the "Dockablewindow"  to visible true of false.
If you do this then it is set as Visible or not in the code.
If you leave it not coded, you can use the the checkbox in the Window>>User Interface.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
