VBA macro
VBA macro
sandreev
VBA macro
sandreev
Hello guys,
I'm quite inexperienced with VBA so if any of you can help me get this macro to work will be very much appreciated. I am trying to extract X Y Z of work points in the 3D model and create a General table into a drawing with the info, 1st column to be with the name of the work point, 2nd column empty, the rest are X Y Z. It's highlighting the last row but I don't know how to fix it
Set oCustomTable = oSheet.CustomTables.Add("", ThisApplication.TransientGeometry.CreatePoint2d(15, 15), 5, oSheet.Centermarks.Count, oTitles, oContents, oColumnWidths)
The whole code is this
Public Sub CreateGLOBALtest()
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
' Set the column titles
Dim oTitles(1 To 5) As String
oTitles(1) = "RPS"
oTitles(2) = "Note"
oTitles(3) = "X (mm)"
oTitles(4) = "Y (mm)"
oTitles(5) = "Z (mm)"
' Set the contents of the custom table (contents are set row-wise)
Dim oCenterMark As Centermark
Dim oPoint As Point
Dim i As Integer
i = oSheet.Centermarks.Count * 5
ReDim oContents(1 To i) As String
i = 1
For Each oCenterMark In oDrawDoc.ActiveSheet.Centermarks
Set oPoint = oCenterMark.ModelWorkFeature.Point
oContents(i) = oCenterMark.ModelWorkFeature.Name
i = i + 2
oContents(i) = Round((oPoint.X * 10), 10)
i = i + 1
oContents(i) = Round((oPoint.Y * 10), 10)
i = i + 1
oContents(i) = Round((oPoint.Z * 10), 10)
i = i + 1
'Debug.Print oPoint.X & ", " & oPoint.Y & ", " & oPoint.Z
Next
' Set the column widths (defaults to the column title width if not specified)
Dim oColumnWidths(1 To 5) As Double
oColumnWidths(1) = 3
oColumnWidths(2) = 6
oColumnWidths(3) = 2.3
oColumnWidths(4) = 2.3
oColumnWidths(5) = 2.3
' Create the custom table
Dim oCustomTable As CustomTable
End Sub
Thanks in advance!
Mark.Lancaster
@sandreev
When it comes to programming needs for Inventor use the Inventor Customization forum for that https://forums.autodesk.com/t5/inventor-customization/bd-p/120
I will request your posting to be relocated there to best suit your needs.
Mark Lancaster
