How to get titleblock details from drawing
shivam7C2Q8
shivam7C2Q8
Hii I am wondering if we can fetch the title block details like scale, title, Dwg number, Revision  from drawing like here via apis.
I found out this values are set from field text but don't know how to get these values ?
bradeneuropeArthur
Can you share the drawing template to help you programming this!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
FINET_Laurent
Hi @shivam7C2Q8,
It is a bit tricky but achievable. Here is an example of mine :
Dim actDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument
Dim s As Sheet = actDoc.ActiveSheet
Dim t As TitleBlock = s.TitleBlock
Dim tDef As TitleBlockDefinition = t.Definition
For Each txtBox As TextBox In tDef.Sketch.TextBoxes
	If txtBox.Text = "<AUTEUR>" Then  MsgBox(t.GetResultText(txtBox))
Next
Basicly prompt entries are created when adding a text box in the title block, and formating as folowing : <PropertyName>
So basicly I just search in the text boxes collection and fine the one that I'm looking for, then see it's value.
You could use then a small function like this :
Sub main
	Dim val As String = find_value("AUTEUR")
	MsgBox(val)
End Sub
Function find_value(propertyName As String) As String
		If txtBox.Text = "<" & propertyName & ">" Then  Return t.GetResultText(txtBox)
	Next
	Return "Property doesn't exist"
End Function
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
shivam7C2Q8
Hii I have downloaded these sample drawings I will attach one below
shivam7C2Q8
Hi @FINET_Laurent
above code I tried I am getting the properties but not its values for ex. in orignal post the scale is 1/2 in titleblock but I am not getting that value using t.GetResultText(txtBox). It is returning empty string.
thanks,
Shivam
FINET_Laurent
Hi @shivam7C2Q8,
My code is working flawless on my end :
Sub main
	Dim val As String = find_value("Echelle de la vue d'origine")
	MsgBox(val)
End Sub
	Next
End Function
Note that the text specified in the string (line 2) has to match perfectly (capital letters, spaces, ..).
Also check the prompt itself has a value and is not empty.
Kind regards,
FINET L.
