iLogic & Vault Copy file to new folder
Dominik.Janshoff
Dominik.Janshoff
Hello Everyone,
I want to copy a bunch of files into a new folder. Therefor I tried the new iLogic Vault snippest adn took a look into the help documentation.
  •   CopyLocalFile Method
  •   GetFileCopyBySourceFileNameAndAutoNumber Method
  •   GetFileCopyBySourceFileNameAndNewName Method
  •   GetFileCopyBySourceFileSearchAndAutoNumber Method
  •   GetFileCopyBySourceFileSearchAndNewName Method
Is it correct, that it is only possible to copy the file in the same folder? If not can anybody provide me an example, where the file is copied to a new existing folder?
Thank You
e2000773
I would also like to know this. Vault does have the function ”copy to”, so it should be possible, but probably not with these snippets. So what kind of a line of code does it require?
mslosar
Vault uses Copy Design. I do not know if there's an API for it though.
