Export Face As DXF
Export Face As DXF
mitchELAHB
Message 1 of 10
Export Face As DXF
mitchELAHB
I'm trying to export a face from a solid using iLogic. I have made the face a named entity and have been trying to export the face using the GeomToDXFCommand API, but have had no luck in being able to pass the face to the API. I can't export the flat pattern as I only want the face in its folded form. Is there a way to get the functionality of 'Right Click' > 'Export Face As' using iLogic?
Replies (9)
Message 2 of 10
gerrardhickson
Try this:
It requires you to have a face selected before running. You could select this face programmatically or manually.
Sub Main()
Dim oCtrlDef As ButtonDefinition
oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("GeomToDXFCommand")
Dim oDXFFullFileName As String
oDXFFullFileName = "C:\Temp\Face.dxf"
ThisApplication.CommandManager.PostPrivateEvent( PrivateEventTypeEnum.kFileNameEvent, oDXFFullFileName)
oCtrlDef.Execute
End Sub
Borrowed from here:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/api-quot-export-face-as-dxf-quot-in-...
Message 3 of 10
mitchELAHB
Thanks, I've implemented something similar with a try/catch statement when setting the face name.
Function SaveFace(FaceName As String, SavePath As String)
	'finding entity called 'FaceName', providing error if can't find
	Dim oNamedEntities = iLogicVb.Automation.GetNamedEntities(ThisDoc.Document)
	Try
		oFace = oNamedEntities.FindEntity(FaceName)
	Catch
		MessageBox.Show("Cannot find face called '" & FaceName & "'! DXF not saved.", "Error saving file")
		Exit Function
	End Try
	'selecting entity called 'FaceName'
	ThisDoc.Document.SelectSet.Select(oFace)
	'Export selected face to 'SavePath'
	Dim oCmdMgr As CommandManager = ThisApplication.CommandManager
	Dim oCtrlDef As ButtonDefinition = oCmdMgr.ControlDefinitions.Item("GeomToDXFCommand")
	oCmdMgr.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, SavePath)
	oCtrlDef.Execute
End Function
This works well for my needs, but I did wonder if there was a more elegant solution than selecting the face programmatically.
Cheers
Message 4 of 10
gerrardhickson
Do you mean you would like to export the face directly? E.g. oFace.exporttodxf?
If that's what you were hoping for, then it seems that you're out of luck. I think the exit face as DXF was introduced to inventor relatively recently, so it hasn't been included in the API yet.
Message 5 of 10
mitchELAHB
Thanks for that. Yeah, I was hoping to be able to do some a bit more eloquently, but what I have works.
Cheers
Message 6 of 10
MSt-Louis
Thanks for sharing this code.
Very helpful for me.
Message 7 of 10
MSt-Louis
@mitchELAHB , it works great.
Instead of exporting a face from "ThisDoc", I would like to export a face from a known file, because I want to run this rule in a DWG file to export faces from multiple .ipt files that are there.
Eg.
How can I change this line to select oFace from a specific known file?
Thank you.
Message 8 of 10
mitchELAHB
Would something like this do?
Sub main()
	Dim sFilePath As String = "C:\TEST\Test.ipt"
	Dim oDoc As Document = ThisApplication.Documents.Open(sFilePath, True) 	'False = open invisible, True = open visible. invisible is much faster.
	Dim oFaceName As String = "Test"
	Dim oSavePath As String = "C:\TEST\Test.dxf"
	SaveFace(oDoc, oFaceName, oSavePath)
	oDoc.Close
End Sub
Function SaveFace(oDoc As Document, FaceName As String, SavePath As String)
	Dim oNamedEntities = iLogicVb.Automation.GetNamedEntities(oDoc)
	Try
	Catch
		Exit Function
	End Try
	Dim oFolder As String = System.IO.Path.GetDirectoryName(SavePath)
	'creating folder if not exist
	If Not System.IO.Directory.Exists(oFolder) Then
	    System.IO.Directory.CreateDirectory(oFolder)
	oDoc.SelectSet.Select(oFace)
	oCtrlDef.Execute
	'deselecting entity called 'FaceName'
	oDoc.SelectSet.Clear
End Function
Unfourtnately I think you'll need to open the files visibly to get the GeomToDXFCommand to work, which slows things down a little. I haven't tested this code much so you might need to add a few tweeks.
Message 9 of 10
MSt-Louis
Thank you for the code. Yes it works !
The only issue is here:
If I set the boolean to False (wich I think is a good idea to open invisible), the export does not take place. But I think you already knew this.
If I have no choice, I'll add oDoc.Close at the end of your code.
Message 10 of 10
mitchELAHB
Yes, as far as I know the document will need to be opened. Good point on closing the file, that slipped my mind, I'll update my code for any future searches that find this topic.
