How to delete child surface after split from big surface
SandmanINV
SandmanINV
Hi people,
i use VBA editor to create lines, then split a big face to many child surfaces. Like this..
As you see, i have many surfaces have equal dimension and many surface unequal dimension.
I want to delete all surface have equal dimension automatically.
How should i do now ? Thank you
bradeneuropeArthur
Are these rectangle all separate surface?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
SandmanINV
Hi there, thank for your reply.
I updated my file, you can download and open it.
Thanks you.
SandmanINV
Here is my file.
I using inventor 2019. I upload step file and ipt file.
Thank you.
