iLogic Help
iLogic Help
iLogic Help
I am designing some code to provide the quantity of rungs for a ladder of a certain order size with a certain space from top and bottom of concrete.
If they order 4000mm, the amount of rungs that can fit are 4000 ("ORDER")-200("First_rung") / 300 ("RungSpace") = 12.67 so 13.
This makes the space between the bottom rung and the ground: 4000 - [ 12*300 (one less) +200 ] = 200mm
The critical points are when the bottom rung is 0<x<50, in these cases we want parameter "First_rung" to be changed to 150. 0 is fine because in this case it will compute 12 rungs and 50 is fine because the bottom rail will be touching the ground. I have some code working that was half right, then i re-wrote in an effort to clean it up but now the "Rungs" parameter is just staying at 0.
Mark.Lancaster
@Anonymous
iLogic/programming questions and issue should be posted in the Inventor Customization forum https://forums.autodesk.com/t5/inventor-customization/bd-p/120 for best results.   I will have the moderator relocate it there to better suit your needs.
Mark Lancaster
bradeneuropeArthur
use floor()
or Use Ceil()
e.g.:
parx = 12.34
pary =Ceil(parx) >>> gives 13
pary =floor(parx) >>> gives 12
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Arthur,
My question was more how to ensure the spacing changes from 150 to 200 and back to 200 when not needed. But i figured it out by getting rid of the value + (or -) 50 line and making it a direct swap.
Thanks for looking into it though!
SyntaxEditor Code Snippet
Parameter("Rungs") = Ceil((Order-FirstRung)/RungSpace)
VarSpace = Order-FirstRung-(Parameter("Rungs")-1)*300
If (VarSpace > 0) AndAlso (VarSpace < d2) Then
	Parameter("FirstRung") = 150
	Else
		Parameter("FirstRung") = 200
