How to create a new file name adding suffix in a new folder?
ikilic1461
Message 1 of 14
ikilic1461
Hello ;
I have a ilogic parametric assembly here and I want to add a prefix to all items ,including sub assemblies ,parts in product tree and save as to a new folder(like pack and go )
For example ; firts item's name "Oil Entry DOF Tube" , after apply my desired rules I want to add project name as prefix.
I will put a button and write "Enter project name "
Project name : PA366
Then it will become "PA366_Oil Entry DOF Tube"
Replies (13)
Message 2 of 14
bradeneuropeArthur
You could use ilogic copy design, found in the ribbon zero documents!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 14
ikilic1461
ıs there another solution to be able to add to the form with rule?
Because I have some form paremeters , I also want to include project number too , then want to change all item's file name with this prefix.
Thanks .
Message 4 of 14
ikilic1461
Hello @bradeneuropeArthur ;
I have some parameters from the parts in the assembly , when I use ilogic copy design , in the copied assembly the parameter names stay as previous one , so the rule gives error.
You can see below screenshoot, in model tree it is with prefix name which created with ilogic design copy but in the rule they remain as previous one.
If you help me I would be grateful
Message 5 of 14
WCrihfield
Hi @ikilic1461.  Besides what I mentioned on your other current forum topic, below is another possible workaround way to 'fix' the rule afterwards, if needed, but this one can be pretty tricky to implement correctly.  This would be something you would need to run after the design copy process has completed, to help fix the contents of the iLogic rule to reflect the new component names.
It is not 'perfect', but may work OK if working from a Template type situation (copying a template assembly files to new files).  This is because it is expecting the names of the components in the rule to not already have a 'prefix' in their names.  If they do already have a prefix in their names, such as when copying one 'copied' assembly to make another, then the 'find & replace' task will not be working with the correct 'find' text.  If that is the case, then you may need to redefine how the 'find' text is dictated by replacing old/previous prefix with new/current prefix, instead of just removing prefix.
Sub Main
	Dim oADoc As AssemblyDocument = TryCast(ThisDoc.Document, Inventor.AssemblyDocument)
	If oADoc Is Nothing Then Logger.Debug(iLogicVb.RuleName & " exited (Wrong DocumentType)") : Return
	Dim oOccs As ComponentOccurrences = oADoc.ComponentDefinition.Occurrences
	If oOccs.Count = 0 Then Return
	Dim sPrefix As String = InputBox("Enter Prefix Text.", "Prefix", "")
	If sPrefix = "" Then Return
	'<<< a Dictionary to hold each 'old/previous' and 'new/current' component BrowserNode name, in pairs, in a list >>>
	'<<< each 'entry' has a 'Key' and a 'Value' (Key = old or previous name, Value = new or current name) >>>
	Dim oDict As New Dictionary(Of String, String)
	'<<< a transaction bundles multiple actions into one item in the UNDO list >>>
	Dim oTrans As Inventor.Transaction
	oTrans = ThisApplication.TransactionManager.StartTransaction(oADoc, "Update iLogic Rule Component Names")
	For Each oOcc As ComponentOccurrence In oOccs
		'<<< get name of component BrowserNode without the 'Prefix' >>>
		Dim sOccNameWithoutPrefix As String = oOcc.Name.Replace(sPrefix, "")
		'<<< if sOccNameWithoutPrefix is not already in dictionary, then add it, along with current name >>>
		If Not oDict.ContainsKey(sOccNameWithoutPrefix) Then
			oDict.Add(sOccNameWithoutPrefix, oOcc.Name)
		End If
	Next 'oOcc
	If oDict.Count = 0 Then : oTrans.Abort : Return : End If
	'<<< run the custom Sub routine below with following line of code >>>
	'<<< IMPORTANT:  EDIT RULE NAME IN NEXT LINE >>>
	FindReplaceTextInRule(oADoc, "RuleName", oDict)
	oTrans.End
End Sub
Sub FindReplaceTextInRule(oDoc As Inventor.Document, sRuleName As String, _
oOldAndNewPairs As Dictionary(Of String, String))
	If oDoc Is Nothing OrElse oDoc.IsModifiable = False Then Return
	If sRuleName = "" Then Return
	If oOldAndNewPairs Is Nothing OrElse oOldAndNewPairs.Count = 0 Then Return
	Dim oRule As iLogicRule = iLogicVb.Automation.GetRule(oDoc, sRuleName)
	If oRule Is Nothing Then
		Logger.Debug("iLogic Rule named '" & sRuleName & "' not found!")
		Return
	End If
	Dim sRuleText As String = oRule.Text
	If sRuleText = "" Then Return
	For Each oEntry As KeyValuePair(Of String, String) In oOldAndNewPairs
		Try
			sRuleText = sRuleText.Replace(oEntry.Key, oEntry.Value)
		Catch
			Logger.Error("Error editing iLogic Rule named " & sRuleName & vbCrLf & _
			"while replacing:  " & oEntry.Key & vbCrLf & _
			"with:  " & oEntry.Value)
		End Try
	Next 'oEntry
	oRule.Text = sRuleText
End Sub
I also have an alternative custom Sub routine with the same name, but which requests a single 'text to find' and 'text to replace the with', instead of a Dictionary(Of String, String), for when you only need to replace one term in a rule.
sTextToFind As String, sReplacementText As String)
	If sRuleName = "" OrElse sTextToFind = "" Then Return
		Return
	End If
	Try
		sRuleText = sRuleText.Replace(sTextToFind, sReplacementText)
	Catch
		"while trying to replace:  " & sTextToFind & vbCrLf & _
		"with the following:  " & sReplacementText)
	End Try
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
Message 6 of 14
bradeneuropeArthur
You should use a static occurrence name which stays always the same...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 14
ikilic1461
Hello @WCrihfield ;
I am so grateful for your endless support, But , I see I couldn't solve my problem yet.
I also attached  my study here. If you have time you may integrate your statements .
Many thanks
Message 8 of 14
ikilic1461
My study attached in the previous message.
I couldn't understand how to do it . If you have time and solve this issue I would be grateful.
Many thanks.
Message 9 of 14
bradeneuropeArthur
I will support you. Will come back to you, ok?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 14
ikilic1461
Thank you , I will be waiting for it.
Message 11 of 14
bradeneuropeArthur
First create a  Custom Property in each part in the assembly Called "MyDisplayName" and give this the values as per picture.
Than use this i-locig code to set each time you copy the value back to the default (Displayname)
Dim a As AssemblyDocument = ThisAssembly.Document
Dim ac As AssemblyComponentDefinition = a.ComponentDefinition
Dim ao As ComponentOccurrence
For Each ao In ac.Occurrences
	Dim d As Document = ao.Definition.Document
	Dim dps As PropertySet = d.PropertySets.Item(4)
	Dim dp As [Property] = dps.Item("MyDisplayName")
	ao.Name = dp.Value
	Next
Now the problem from the rename is away since the displayname is always static or overwitable with the "MyDisplayName" value of each occurence in this assembly.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 14
ikilic1461
I created a custom property in 7 parts which I got parameters in my assembly  as you mentioned "MyDisplayName".
But at the end I got this error . Then form didn't work.
I am also attaching model here.
MyDisplayName = Oil Entry DOF Tube.ipt:1
MyDisplayName = Interval DOF Tube.ipt:1
MyDisplayName = End DOF Tube.ipt:1
MyDisplayName = DOF Oil Entry End Flange.ipt:1
MyDisplayName = End Stop Board Packing Block.ipt:1
MyDisplayName = DOF Tube Support Board.ipt:1
MyDisplayName = Petal Washer Seal.ipt:1
Message 13 of 14
bradeneuropeArthur
I have got it working for you.
What you forgot is to add "MyDisplayName" to each compontent even it is an empty string.
Also changed this in the code:
	Try
	ao.Name = dp.Value
		Catch
		End Try
	Next
See the movie for explanation too
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 14
ikilic1461
Even  if I applied to the all items I got en error again ;
There is something wrong or missing.
If possible , can you share your modifed file?
