how do i run iloigc on files that are create form save and replace or Save as?
Darkforce_the_ilogic_guy
Advisor Advisor
I have a problem ... I have create an ilogic code that I would like to run on files that have just been create by using the Save and Replace command
My problem is that it seens no matter what i do .... I run on the orginal file , not the new file that was just created .
It might have done this before I update to inventor 2020.2.1 fra inventor 2020.2 but I am not sure. How do I get this to work ?
bradeneuropeArthur
I have followed your questions here in the forum closely the last time.
I personally think that your level of programming has reached the point that you better should start programming your own add ins. The questions are most times easier to solve since you have access to more objects directly. Also you are able to use all kind of events within inventor. For example this specific question can easily been solved using the user input events of inventor. For the future it is easier to start programming in vb.net or equal.
If you need any further help, please let me know!
Regards.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Do you have any good resource that I can use to leard it ? and do you know I  would to that i want as an addin ?
Because some things are easier, also for this question.
I will send you some interesting links Monday, ok?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Sound Good Love to leard ... nerdy stuff 😁.. it there the ready power is
Some links to start with!
https://knowledge.autodesk.com/search-result/caas/simplecontent/content/my-first-inventor-plug-overv...
And in inventor the help files:
If you need further support please let me know.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
