VBA code to quickly check in and check out files in vault from inventor drawing?
francesco.dinh
francesco.dinh
Whenever I have to make quick changes to an idw that's already checked in and released (say a dimension is misplaced or such) I'll have to do a "modifica leggera", an edit that doesn't change the revision number. The process is more or less like this.
- From the vault sidebar in the inventor drawing, I'll edit the state to "modifica leggera". This removes the released state from the part without adding a revision number.
- check out the file
- make the changest that I want and save
- check in the file
- release it in vault
This whole "modifica leggera" > check out > edit > save > check in > release gets really repetitive, especially if I have to do it for a bunch of released files.
Is there a way to have a script to make this process automatic? I'm talking especially about "modifica leggera" > check out and, afterwards, check in > release.
Thanks in advance for any input.
bradeneuropeArthur
Hi @francesco.dinh<,
Absolutely a good idea for the "Idea station".
I will vote it if your create it...
There are (For this exampe) so many steps to take/do, and in general this could possibly defined in one or two commands like:
(Change state > Release>>>> WIP
Check out)
and the other command:
(Change state> WIP>>>> Release
Check in)
What you could do is write your own add in for it and combine these command to one custom command.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
francesco.dinh
Hey, thanks for your reply, I'm glad I'm not the only one who find this process so long! I'm afraid I don't have nearly the skillset to create an inventor addin, but I'd be glad if somebody were to try and do it.
I wanted to start much more humbly with a VBA macro, but I'm not 100% sure how inventor and vault communicate between each other (especially because they might not be both "speaking" VBA, as others have pointed out). If it's jus a matter of chunking together a few VBA lines in a macro that's doable, but my knowledge stops there. I'm hoping other people have faced this before!
bradeneuropeArthur
What version of Vault are you using?
I could help you to create you first add in for inventor(Vault) using VB.net, if you like!
Maybe the first step is to create a new idea in the Idea station.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
GeorgK
Hello @bradeneuropeArthur ,
very interesting idea. I use Vault 2017. This would save a lot of time.
https://forums.autodesk.com/t5/inventor-customization/ilogic-open-file-from-vault/td-p/5701827
Georg
