iLogic - Open File From Vault
Message 1 of 13
Is it possible to open a file from the Vault using iLogic?  I want to batch process a large group of files, but the examples I am finding all show how to do it based on grabbing a file from the local workspace and I need to get the latest file from the Vault.
Using Vault Basic 2015 now, shortly upgrading to Vault Workspace (not sure if that affects anything with this).  Specifically I am trying to tweak this script to search for a list of files from the Vault and loop through them:
http://www.mastergraphics.com/wordpress/2014/batch-processing-with-ilogic/
Replies (12)
Message 2 of 13
Richard.MM
I solved a similar problem and found that using iLogic can not access to the Vault. You must use .net.
Message 3 of 13
Jef_E
@Richard.MM Hi, could you post your solution in .net? I'm also interested in this. Would be great to see a example.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Message 4 of 13
Richard.MM
Here is the code that download drawing from the vault and open it.
But you'll have to modify it for his own use.
VB.net:
Imports Autodesk.DataManagement.Client.Framework.Vault
Imports Autodesk.Connectivity.WebServicesTools
Imports VDF = Autodesk.DataManagement.Client.Framework
Imports ACW = Autodesk.Connectivity.WebServices
Imports System.Collections
Imports System.Windows.Forms
Public Class Otevr_zVault
    Dim fileIters As System.Collections.Generic.ICollection(Of VDF.Vault.Currency.Entities.FileIteration)
    Public Shared kontrola As String
    Public Sub stahni_vykr()
        Dim results1 As VDF.Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn("xxx", "xxxx", "Administrator", "", VDF.Vault.Currency.Connections.AuthenticationFlags.WindowsAuthentication, Nothing)
        If Not results1.Success Then
            MsgBox("Error1")
        Dim connection As VDF.Vault.Currency.Connections.Connection = Nothing
        connection = results1.Connection
        Dim m_inventorApp As Inventor.Application = Nothing
        ' get running Inventor
        Try
            m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        Catch ex As Exception
            MsgBox("Error2")
        End Try
        Try
            If m_inventorApp Is Nothing Then
                MsgBox("Error3")
                Return
        Catch
        End Try
        m_inventorApp.Visible = True
        Dim oDoc As Inventor.Document
        oDoc = m_inventorApp.ActiveDocument
        Dim fullfilename1 As String = oDoc.FullFileName
        Dim vykr As String
        If Not fullfilename1 = Nothing Then
            If oDoc.DisplayName.EndsWith(".ipt") Or oDoc.DisplayName.EndsWith(".iam") Then
                vykr = Microsoft.VisualBasic.Left(oDoc.DisplayName, InStrRev(oDoc.DisplayName, ".")) & "idw"
            ElseIf oDoc.DisplayName.EndsWith(".idw") Then
                vykr = oDoc.DisplayName
            Else
                vykr = oDoc.DisplayName & ".idw"
        Else
            MessageBox.Show("Error4")
            Return
        Dim oFolder3 As String = Microsoft.VisualBasic.Left(fullfilename1, InStrRev(fullfilename1, "\") - 1)
        Dim oFolder2 As String = Microsoft.VisualBasic.Left(oFolder3, InStrRev(oFolder3, "\"))
        If fullfilename1 = Nothing Then
            MsgBox("Error5")
            Return
        Dim fullfilename As String = oFolder2 & "Drawings\" & vykr
        Try
            Dim oFileIteration As VDF.Vault.Currency.Entities.FileIteration = Nothing
            Try
                'convert local path string to vault format
                Dim VaultPath As String = fullfilename
                If VaultPath.Contains("D:\Vault_Working\") Then
                    VaultPath = VaultPath.Replace("D:\Vault_Working\", "$/")
                ElseIf VaultPath.Contains("E:\Vault_Working\") Then
                    VaultPath = VaultPath.Replace("E:\Vault_Working\", "$/")
                Else
                    MsgBox("Error6 " + VaultPath)
                    Return
                VaultPath = VaultPath.Replace("\", "/")
                Dim VaultPaths() As String = New String() {VaultPath}
                Dim DocService As ACW.DocumentService
                DocService = connection.WebServiceManager.DocumentService
                Dim files As ACW.File() = Nothing
                Try
                    files = DocService.FindLatestFilesByPaths(VaultPaths)
                Catch
                End Try
                Dim file As ACW.File
                file = files(0)
                oFileIteration = New VDF.Vault.Currency.Entities.FileIteration(connection, file)
                MsgBox("Error7")
            End Try
            If oFileIteration IsNot Nothing Then
                'get settings
                Dim oSettings As VDF.Vault.Settings.AcquireFilesSettings = New VDF.Vault.Settings.AcquireFilesSettings(connection)
                oSettings.DefaultAcquisitionOption = VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download 'Or VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Checkout
                oSettings.AddEntityToAcquire(oFileIteration)
                kontrola = "NE"
                connection.FileManager.AcquireFiles(oSettings)
            Dim Rodice As New Rodice
            Call Rodice.GetWhereUsed()
            Return
        Finally
            VDF.Vault.Library.ConnectionManager.LogOut(connection)
        End Try
        m_inventorApp.Documents.Open(fullfilename)
        kontrola = Nothing
    End Sub
End Class
Message 5 of 13
I get error-
Type 'Rodice' is not defined
Message 6 of 13
Richard.MM
Hello
These two lines are not necessary there
Simply delete them.
Message 7 of 13
maxim.teleguz
Did you ever Get Whereused to work?
Message 8 of 13
Richard.MM
yes
Message 9 of 13
maxim.teleguz
are you able to post any code that you optimized to work for you?
I have been trying so hard to get it to work for us and we can get it to work but not consistently and it requires a lot of set up.
Message 10 of 13
Richard.MM
I am sending the code we are using and it works.
MsgBox outputs are written in Czech language.
 Public Sub GetWhereUsed(m_inventorApp_rr As Inventor.Application)
        m_inventorApp = m_inventorApp_rr
        If m_inventorApp.ActiveDocument.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
            MessageBox.Show("Zdarec, máš otevřený výkres, akce bude přerušena", "Nespi!", MessageBoxButtons.OK, MessageBoxIcon.Error)
            Exit Sub
        Dim hledam As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) + System.IO.Path.GetExtension(oDoc.FullFileName)
        Dim results As VDF.Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn("xxxxx", "yyyyy", "zzzzz", "wwwww",
        Nothing)
        If Not results.Success Then
            MsgBox("Připojení k Vaultu se nezdařilo")
          connection = results.Connection
        Dim Defss As PropDef() = connection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("ITEM")
        Dim Prop As PropDef = Nothing
        For Each def As PropDef In Defss
            If def.DispName = "Revision" Then
                Prop = def
        Next def
        Dim searchCondition As SrchCond = New SrchCond()
        searchCondition.PropDefId = Prop.Id
        defs = connection.WebServiceManager.PropertyService.FindPropertyDefinitionsBySystemNames("FILE", {"ClientFileName"})
        srchCond.PropDefId = defs(0).Id
        srchCond.PropTyp = PropertySearchType.SingleProperty
        srchCond.SrchRule = SearchRuleType.Must
        srchCond.SrchOper = 3
        srchCond.SrchTxt = hledam
        SrcConds(0) = srchCond
        Try
            files = connection.WebServiceManager.DocumentService.FindFilesBySearchConditions(SrcConds,
        Nothing,
        Nothing,
        True,
        True,
        bookmark,
        searchStatus)
        Catch
            MsgBox("Nemohu ziskat soubor z Vaultu")
        End Try
        Dim assocArray2 As FileAssocArray() = Nothing
        For Each chci In files
            If chci.Name = hledam Then
                assocArray2 = connection.WebServiceManager.DocumentService.GetLatestFileAssociationsByMasterIds(New Long() {chci.MasterId},
        FileAssociationTypeEnum.All,
        True,
        FileAssociationTypeEnum.None,
        True,
        True,
        True,
        True)
        Next
        If assocArray2(0).FileAssocs Is Nothing Then
            MessageBox.Show("Nemohu najít žádný výkres, zřejmě to budš muset udělat ručně!")
            Return
        Dim vykresy(assocArray2(0).FileAssocs.Count) As String
        If Not assocArray2 Is Nothing Then
             For i = 0 To assocArray2(0).FileAssocs.Count - 1
                If assocArray2(0).FileAssocs(i).ParFile.Name.EndsWith("idw") Then
                    If Not assocArray2(0).FileAssocs(i).ParFile.Name Is Nothing Then
                        vykresy(i) = assocArray2(0).FileAssocs(i).ParFile.Name
            Next
        Else
            MessageBox.Show("Nemohu najít žádný výkres.")
            Exit Sub
        Dim arr As New ArrayList
        For i As Integer = 0 To vykresy.Length - 1
            If Not arr.Contains(vykresy.GetValue(i)) Then
                arr.Add(vykresy.GetValue(i))
        Next
        vykresy = arr.ToArray(GetType(String))
        Me.Show()
        Dim prvni As Integer = 0
        For Each sr In vykresy
            prvni = prvni + 1
            If Not sr Is Nothing Then
                If prvni = 1 Then
                    Me.CheckedListBox1.Items.Add(sr, True)
                Else
                    Me.CheckedListBox1.Items.Add(sr, False)
        Next
        TextBox1.AppendText(System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) + ".idw")
    End Sub
Message 11 of 13
JBerns
Would this VB.NET code work with Vault Basic?
We are currently on 2019 versions, but upgrading soon.
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 12 of 13
Richard.MM
I don't know, it was originally made for Vault professional 2017. Now we have switched to Professional 2022 and after recompiling it into new libraries it still works.
Message 13 of 13
rcolon9E4ZX
@Richard.MM ,
Do you have a solution for VBA? This is what I have available for connecting with INV2022. Is there a shift for Autodesk using VB.NET, and is VBA going to get discontinued?
Kind regards,
Rafael
