Help: iLogic Code to Insert Prompt Title Blocks
ngdnam88
ngdnam88
Hi friends,
Please help me the iLogic Code to Insert the Prompt Title Blocks into the Drawing. I tried:
Try
	ActiveSheet.TitleBlock = "PROMPT BORDER (1)"
Catch
End Try
but the Title Block didn't inserted.
bradeneuropeArthur
"Border" = not "Boder"
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Use this piece of code to replace:
Dim a As DrawingDocument = ThisDrawing.Document
Dim b As TitleBlockDefinition = a.TitleBlockDefinitions.Item("PROMPT BORDER (1)")
a.ActiveSheet.TitleBlock.Delete
a.ActiveSheet.AddTitleBlock(b)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
ngdnam88
I tried your code but I got an error. Please help me. Thanks,
ngdnam88
I forgot to give the important point: The title block that I used need to fill information to "Prompted Entry" table:
With the normal Title Block, both of iLogic codes run perfect!
ngdnam88
bradeneuropeArthur
Have you checked your spell?
Dim b As TitleBlockDefinition = a.TitleBlockDefinitions.Item("PROMPT BODER (1)")
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
