Is there a way to use Content Center family dialog box directly?
Stakin
Stakin
Is there a way to call the Content Center family dialog box directly?
Or call it out by commandermanger?
bradeneuropeArthur
Can you show in some screenshot of what you mean?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Stakin
https://help.autodesk.com/view/INVNTOR/2021/ENU/?guid=GUID-8EDD3824-5497-43D9-9808-D184EF43D413
Use the Family dialog box to select a family member to place from Content Center.
Access
In the Place, Place Feature, or Replace from Content Center dialog box, select a part family, and click OK. Note: The Family dialog box is skipped when you use AutoDrop. Right-click a Content Center part in the graphic window or in the browser, and select Change Size.
The available options depend on how you access the dialog box.
Is there a way to Call Family dialog box directly skip the the Place, Place Feature, or Replace from Content Center dialog box?
A.Acheson
Here is a link to retrieve the commands list by code. I usually search this list by the command name or the information in the tool tip.
Here is the CC commands and I found these here
CommandDescription
CCV2BatchPublishButtonBatch Publish to Content Center
CCV2ChangeSizeButtonChange size of Standard Component
CCV2ChangeSizeButtonCMChange size of Standard Component
CCV2EditorButtonOpen Content Center Editor
CCV2OpenButtonOpen Component from Content Center
CCV2OpenCWButton Access Autodesk Manufacturing Supplier Content Center
CCV2PlaceButtonPlace Component from Content Center
CCV2PlaceButtonCMPlace Component from Content Center
CCV2PlaceFeatureButtonPlace Feature from Content Center
CCV2PlaceFeatureButtonCMPlace Feature from Content Center
CCV2PublishButtonPublish Part to Content Center
CCV2ReplaceButtonReplace Component with Component from Content Center
CCV2ReplaceButtonCMReplace Component with Component from Content Center
CCV2RSCButtonRefresh Standard Components
Regards
Alan
Stakin
Thank you very much,It seems no entry to call the family dialog box directly
The family dialog box will appear when Place,replace the CC part normally in the selected CC family ID  name.
Thanks for your reply.
