Give one example to trim sketch by vba code
vjyupr4047
Message 1 of 10
vjyupr4047
Hello Sir,
I want trim hexagon quater portion by vba.Can you please give one example to trim sketches?
Replies (9)
Message 2 of 10
王承之pmhker
也许您可以在 Inventor 定制论坛中发帖
发明家 iLogic 和 VB.net 论坛 - 欧特克社区
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
王 承之
Autodesk AGN [Inventor 俱乐部] Leader
Inventor Club | Bilibili
AGN L    EESignature
Message 3 of 10
vjyupr4047
Thank you.
Message 4 of 10
A.Acheson
Can you give a sample image of what your looking to achieve? Include any sample code you have also. I can only think of creating an extruding feature. Sample here
But maybe you want to cut existing sketch before extruding? I am not seeing a trim method under sketch line so I am guessing the point is moved or another sequence of methods happen.
Regards
Alan
Message 5 of 10
vjyupr4047
Hello Alan,
Wish you a happy new year and thank you for your reply.
i attached image below.i want trim except 0- 90 deg sketches
Message 6 of 10
bradeneuropeArthur
Isn't it already trimmed.
Could you share the ipt file for us.
1 with no trim
2 with the trim you try to do with VBA
Arthur
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 7 of 10
vjyupr4047
Hello Arthur,
Thank you for your reply.
I want to get output as per attached output.ipt by VBA Code.
Kindly give me one example
Thank you
Vijay
Message 8 of 10
vjyupr4047
after this code i am not able to trim
Dim opt As PartDocument
Set opt = ThisApplication.Documents.Add(kPartDocumentObject, ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
Dim ocd As PartComponentDefinition
Set ocd = opt.ComponentDefinition
Dim op As PlanarSketch
Set op = ocd.Sketches.Add(ocd.WorkPlanes(3))
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
'Project X-Axis
Dim oxaxis As SketchEntity
Set oxaxis = op.AddByProjectingEntity(ocd.WorkAxes(1))
'Project y-Axis
Dim oyaxis As SketchEntity
Set oyaxis = op.AddByProjectingEntity(ocd.WorkAxes(2))
oxaxis.Construction = True
oyaxis.Construction = True
Dim oc As SketchCircle
Set oc = op.SketchCircles.AddByCenterRadius(oTG.CreatePoint2d(0, 0), 1720 * 0.1 * 0.5)
oc.Construction = True
Dim ox As SketchEntitiesEnumerator
Set ox = op.SketchLines.AddAsPolygon(12, oTG.CreatePoint2d(0, 0), oTG.CreatePoint2d(860 * 0.1, 0), False)
Dim cc As DiameterDimConstraint
Set cc = op.DimensionConstraints.AddDiameter(oc, oTG.CreatePoint2d(400 * 0.1, 400 * 0.1))
Message 9 of 10
bradeneuropeArthur
And what do you like to trim here?
Give me also a screenshot how it needs to be after trim!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 10
vjyupr4047
Hello Arthur Knoors,
I want to get vba code as attached image
Vijay k
