Get DrawingCurve from Drawing by Item number (C#)
Hubert_Los
Hubert_Los
I'm trying change simple VBA code to C#
Dim oActiveSheet As Sheet
Set oActiveSheet = ThisApplication.ActiveDocument.ActiveSheet
Dim oDrawingCurve As DrawingCurve
Set oDrawingCurve = oActiveSheet.DrawingViews(1).DrawingCurves.Item(1)
I tried like this:
DrawingView oDrawingView = oActiveSheet.DrawingViews[1];
DrawingCurvesEnumerator oDrawingCurvesEnumerator = oDrawingView.DrawingCurves;
DrawingCurve oDrawingCurveNew = (DrawingCurve)oDrawingView.DrawingCurves[1];
//or
//DrawingCurve oDrawingCurveNew = oDrawingCurvesEnumerator[1];
But it doesn't work.
The same thing happens when he wants to download the Balloon Leader:
LeaderNodesEnumerator oLeader = oBalloon.Leader.AllNodes;
LeaderNode ooLeader = oLeader[1];
JelteDeJong
try it like this:
DrawingDocument doc = (DrawingDocument)ThisApplication.ActiveDocument;
Sheet sheet = doc.ActiveSheet;
DrawingView view = sheet.DrawingViews[1];
IEnumerable<DrawingCurve> curves = view.DrawingCurves.Cast<DrawingCurve>();
DrawingCurve curve = curves.First();
var balloon = sheet.Balloons[1];
LeaderNodesEnumerator nodes = balloon.Leader.AllNodes;
LeaderNode node = nodes[1];
Jelte de Jong
Blog: hjalte.nl - github.com
Hubert_Los
@JelteDeJong
It works, thank you. I have one more question, how can I get, for example, the 5th curve from the curves?
