Compare with wildcard
steven.coxVCM6J
steven.coxVCM6J
Hi all,
This is my first try with iLogic and it does not work as expected.
I want to compare the file name with a string and if the same, add a subject in iProperties.
My_Expression = ThisDoc.FileName(False) 'without extension
If String.Compare(My_Expression,"01000072*") Then
iProperties.Value("Summary", "Subject") = "My Project Name"
 So all parts in this project will be 01000072-##.ipt  The ## represents a unique number.
I want this rule to trigger before a save (or some point when creating the part)
However, what I have puts "My Project Name in all files I run even when the filename does not match.
What am I doing wrong?
Thanks, Steven
JelteDeJong
You might want to have a look at the "Like" operator and change your rule to something like this:
If (My_Expression Like "*01000072*") Then
Jelte de Jong
Blog: hjalte.nl - github.com
A.Acheson
You can check the string without a wild card using the string.contains function.
Dim FileName As String = ThisDoc.FileName(False) 'without extension
If FileName.Contains("01000072") Then
Regards
Alan
steven.coxVCM6J
That is what I needed.  I had tried Like but did not use it correctly.
Thanks so much!
Steven
steven.coxVCM6J
Thanks for the tip!!
Steven
