Getting current running addin location
dsmith
dsmith
Hi
Simple question if I was asking about a windows Application, I need to find the install location of the addin dll.
So I need the equivalent of  Path.GetDirectoryName(Assembly.GetEntryAssembly().Location);
Thanks in Advance
Dave
bradeneuropeArthur
You can see the install paths in the Add-in dialog!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
dsmith
Thanks But I need to get that within the addin itself.
Dave
bradeneuropeArthur
on button press or how?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
Use this than:
'Dim add As ApplicationAddIn = ThisApplication.ApplicationAddIns.item(XXXXX)
Dim add As ApplicationAddIn = ThisApplication.ApplicationAddIns.itemById(XXXXX)
'And use the ID from the add-in selves
MsgBox (add.Location)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
J-Camper
@dsmith,
Are you looking for something like this:
Dim CurrentAssembly As System.Reflection.Assembly = System.Reflection.Assembly.GetExecutingAssembly()
I use it in a version check button, and has a .Location Property "CurrentAssembly.Location"
