Get full filepath for drawing file from vault
jani_karjalainenJFQAG
I have macro which gets drawing file name from excel and I would want to open the file in question from Vault. The tricky part is that I don't know the exact subfolder where it is located so the file needs to be searched somehow.
Any tips how to get that from Vault? I know that Inventor 2024 has the built-in iLogic function for that but we are using 2021 version currently.
bradeneuropeArthur
When you know the local file search path for the drawing, you also know the Vault path.
Replace the "working folder" with "&  and the "\" with "/"!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
The file might be in subfolders that I don't know the path of. I would need to search for subfolders
