Selectable client graphics textbox
Cadkunde.nl
Cadkunde.nl
I have a main assembly with some sub components
I want to be able to select a component, then click a button and get some parameters from the component (length width height) in a textfield hovering over the component (from the main assembly)
Much like during an extrude feature, you get a textfield in which you can set the extrude distance.
I tried examples of Clientgraphics, interactiongraphics, overlaygraphics, but can't figure this one out.
Do I need to make this with mini toolbar?
If possible I would like an example of text box in the screen (I dont want a visual studio form)
JelteDeJong
Have a look at this code. It will create a mini toolbar allowing the user to insert a dimension.
Public Class ThisRule
    Sub Main()
        Dim miniToolBar As New MiniToolbaerWrapper(ThisApplication)
        miniToolBar.Pick()
    End Sub
End Class
Public Class MiniToolbaerWrapper
    Private _interactEvents As InteractionEvents
    Private _stillSelecting As Boolean
    Private _inventor As Inventor.Application
    Private _toolBar As MiniToolbar
    Private _valueEditor As MiniToolbarValueEditor
    Public Sub New(ThisApplication As Inventor.Application)
        _inventor = ThisApplication
    End Sub
    Public Sub Pick()
        _stillSelecting = True
        _interactEvents = _inventor.CommandManager.CreateInteractionEvents
        _interactEvents.InteractionDisabled = False
        _toolBar = _interactEvents.CreateMiniToolbar()
        AddHandler _toolBar.OnOK, AddressOf OkPressed
        _valueEditor = _toolBar.Controls.AddValueEditor("testValue", "", ValueUnitsTypeEnum.kLengthUnits, "123mm")
        _toolBar.ShowApply = False
        _toolBar.ShowOptionBox = False
        _toolBar.Visible = True
        _interactEvents.Start()
        Do While _stillSelecting
            _inventor.UserInterfaceManager.DoEvents()
        Loop
        _interactEvents.Stop()
        _inventor.CommandManager.StopActiveCommand()
        _toolBar.Delete()
    End Sub
    Private Sub OkPressed()
        MsgBox(String.Format("value={0} - Expresion={1}", _valueEditor.Value, _valueEditor.Expression))
        _stillSelecting = False
    End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
Cadkunde.nl
Thanks, I will focus on the mini toolbar today.
https://modthemachine.typepad.com/my_weblog/2012/03/create-a-mini-toolbar.html
The name of 'interaction graphics' got me on a wrong track i guess. They are graphics that automatically disappear after the interaction. Not graphics to interact with.
Though I remember I once saw a movie of someone with clickable graphics in screen.
Dim oNode As GraphicsNode = oClientGraphics.AddNode(1)
oNode.Selectable = True
Then use command manager select events?
And a box like you see with extrude is not possible for 3th party?
