get a part from its file name
TONELLAL
TONELLAL
I have a list of Inventor parts (path + filename), on which I need to get properties.
I know manipulate the part document once I have it, but how can I create it ?
For example :
dim myfilename as string
dim oPart as partdocument
filename = "c:\project\mypart.ipt"  'I know this file exist
'Looking for something like :
set oPart = filename
Alain
MechMachineMan
Using the API, you can find this information easily.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-AA811AF0-2494-4574-8C43-4C22E608252F
oPartDoc = ThisApplication.Documents.Open(filename, boolvis)
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
bradeneuropeArthur
From inside inventor you should use inventor with Inventor.documents.openwithoptions(,,)
 Dim oDoc As Inventor.Document
Dim AppInventor as Inventor.application
AppInventor= getobject(,"Inventor.application")
Dim oNVM As Inventor.NameValueMap oNVM = AppInventor.TransientObjects.CreateNameValueMap AppInventor.SilentOperation = False AppInventor.Visible = True AppInventor.WindowState = Inventor.WindowsSizeEnum.kNormalWindow oDoc = AppInventor.Documents.OpenWithOptions(FrmStartInventorExportUpdateTool.LvProgressLog.SelectedItems.Item(0).Text, oNVM, True)
From outside inventor you should use apprenticeserver with  Inventor.documents.openwithoptions(,,)
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
TONELLAL
Thanks !
I work from Inventor, on an already open iam, so I used first solution.
bradeneuropeArthur
Than please:
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
