generate stock number from parameter values
Keith.Challinor3761
Keith.Challinor3761
using iLogic I am trying to generate an automatic stock number based on existing parameters in a part
i have parameters of "code" (S) , "dia" (500) and "length" (1000) that change based the apart is used , i require a stock code based on those parameters that will look like S/500/1000
could anyone point me in the right direction please
TIA
Keith
bradeneuropeArthur
iProperties.Value("Project", "Stock Number")= Code &"/"& Dia & "/" &Length
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Keith.Challinor3761
Thanks Arthur
let me test and get back to you
appreciate the quick response
Keith
Keith.Challinor3761
EXCELLENT THANK YOU
