Read values from a custom (or general) table in a drawing
Mike_Y2
Mike_Y2
I want to read the value from each row in column 1 of a custom (or general) table.
I will then check if the vaule = "Yes" before running further Ilogic
bradeneuropeArthur
Dim a As Application = ThisApplication
Dim b As Inventor.DrawingDocument = ThisDrawing.Document
Dim t As Inventor.CustomTable = b.ActiveSheet.CustomTables.item(1)
For Each r As Inventor.Row In t.Rows
	If r.Item(1).value = "Yes" then
		MsgBox (r.Item(1).Value)
	Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
ngdnam88
Hi @bradeneuropeArthur
Please help me the code can get value with more column. Example, at each row I want to get value of column 2 and column 4:
