Flat Pattern VBA Editor
i Need help on getting flat pattern. The code below works in ilogic, but i need it to run straight from the VBA editor.
Dim oBaseViewOptions As Inventor.NameValueMap
Set oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
''True = folded view
''False = flat pattern view
oBaseViewOptions.Add("SheetMetalFoldedModel", False)
' Create the drawing view.
Dim oView1 As DrawingView
Set oView1 = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint1, 1#, kDefaultViewOrientation, kHiddenLineDrawingViewStyle, , , oBaseViewOptions)
MechMachineMan
SYNTAX: the arrangement of words and phrases to create well-formed sentences in a language.
What you are trying:
What should work:
Call oBaseViewOptions.Add("SheetMetalFoldedModel", False)
OR
oBaseViewOptions.Add "SheetMetalFoldedModel", False
See linked discussion:
https://stackoverflow.com/questions/5413765/what-are-the-rules-governing-usage-of-brackets-in-vba-fu...
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
i am trying
i just added the call before oBaseViewOptions and it worked.
thanks
