File is a new file, not known to vault
Message 1 of 33
I am runnign an Ilogic script every file on save. The problem is that if this file is new, and hase never been checked in into vault before, then the vault window appears and has to be closed. I would like to run the script only if the file has already beed in vault once before. Is there a way to check this from within Ilogic? Thanks!
Replies (32)
Message 2 of 33
bradeneuropeArthur
What do you mean with vault browser? Don't you mean a vault dialog or something?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 33
uhm? Vault browser? didnt mention a browser..
When you create a new file, it is local, and is unknown to vault till the point where you check it in the first time. What i would need is a way to know via ilogic if a file has ever been in vault or if it is a new local only file.
thanks
Message 4 of 33
bradeneuropeArthur
Using the vault API you can.
Sorry i mean what vault window appears when the file has never been in vault.
Not browser was my mistake.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 33
Its the property sync window that appears..
i want to execute this for some files:
SyntaxEditor Code Snippet
 ThisApplication.Commandmanager.ControlDefinitions.Item("VaultPropertyWriteBack").Execute
But if a file is only local, and was never in vault before, the prop sync window can only be abortet (obviously). I would like to avoid opening it at all, and run above line only if the file exists in vault and not only locally.
Message 6 of 33
bradeneuropeArthur
What version of vault are you using.
With the api of vault it is possible.
Let me know then we cs prepare something maybe
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 33
Thank you!
We have Vault Workgroup 2018,
Build 23,2,3,0
Update 2018.2
Thank you very much!
Message 8 of 33
bradeneuropeArthur
Idea.
Why don't you check in the file first with the inventor Api?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 33
Because often the file sare just tests that get deleted and there are other scenarios where we do not want to check them in before a certain point in time. unfortunately
Message 10 of 33
bradeneuropeArthur
Ok that is good to know.
So if the file is not a vaulted file and checked out you don't run the code I assume than?
Can you please send me a private message so I will not forget?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 33
The checked out part does not matter to me, for me it is only important that it is not vaulted.. in that case, it should not run the command above..
Thank you very much for your help braden, appreciate it!
sent you the message as requested.
Message 12 of 33
bradeneuropeArthur
You could also base it o the read only flag. This means file in vault and not checked out.
But than you are not able to edit the file and edit the properties! Or still you mean in vault and checked out to you. Than edit and synch.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 33
the checked in/out part is done automatically by that script..that part is all working well...
the only part missing is the "hey, this file is not in vault yet.. dont run the next line of code..."
something along the lines of:
If file_is_vaulted = True then
ThisApplication
end if
Message 14 of 33
bradeneuropeArthur
Ok that true.
Only brainstorming....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 33
we found a solution!
we look at the file version. if it is 1, it has never been in vault. if it has been checked in at least twice then it will have version 1. from the second check in it will have version 2 or more. so we miss one execution of the script but that is not a problem.
Message 16 of 33
bradeneuropeArthur
Hi.
I am curious about how you read the version of the file without the vault API?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 33
I am curious too... Since it was in the Iproperties window I assumed it can be read with the normal iproperties.. just noticed while coding that I cannot access the "Details" tab from ilogic..  so its back to base 1...
Message 18 of 33
bradeneuropeArthur
Oke.
Than I can help.
This is a hidden I prop.
These are all available properties also the hidden and sets without custom.
is it with it the version?
#Summary Information
Title
Subject
Author
Keywords
Comments
Last Saved By
Revision Number
Thumbnail
#Document Summary Information
Category
Manager
Company
#Design Tracking Properties
Date Created
Part Number
Project
Cost Center
Checked by
Date Checked
Engr Approved by
Date Eng Approved
User Status
Material
Part Revision
Catalog web link
Part Icon
Description
Vendor
Part Type
Part Type name
Date proxy refreshed
Mfg Approved by
Date Mfg Approved
Cost
Standard
Design Status
Designer
Engineer
Authority
Parameterized Template
Template Row
External Part Revision
Standard Revision
Manufacturer
Standards Organization
Language
Defer Updates
Size Designation
Categories
Stock Number
Weld Material
Mass
SurfaceArea
Volume
Density
Valid MassProps
FlatPatternExtentsWidth
FlatPatternExtentsLength
FlatPatternExtentsArea
SheetMetalRule
LastUpdatedWith
SheetMetalWidth
SheetMetalLength
SheetMetalArea
Material Identifier
Appearance
Flat Pattern Defer Update
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 19 of 33
Nope, 😞 unfortunately no version number in there..
Message 20 of 33
bradeneuropeArthur
I will take a look with the vault API ASAP!
Ok?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
