Showing a Form based upon Null or empty string property
jeremiah_boe
jeremiah_boe
I am attempting to show a form only when the property fields are in an empty string or null state. I am stumbling on the "Date" fields accepting null state. I have attached the code that I have assembled thus far, my error comes from the "creation Date" line.
If ThisDoc.Document Is ThisApplication.ActiveDocument  AndAlso
	iProperties.Value("Summary", "Title") = "" Or
	iProperties.Value("Summary", "Author") = "" Or
	iProperties.Value("Project", "Designer") = "" Or
	iProperties.Value("Project", "Creation Date") = Null Or
	iProperties.Value("Custom", "Drawing Number") = "" Then
		iLogicForm.Show("Model iProperties")
mcgyvr
On my system null is not possible and instead the value when the check box is unchecked is..
So check for this as your trigger
iProperties.Value("Project", "Creation Date") = "1/1/1601"
Curtis_Waguespack
Hi @jeremiah_boe,
see this related thread from the past:
https://forums.autodesk.com/t5/inventor-customization/how-to-null-all-iproperties-with-ilogic/td-p/6...
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum :
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
NachoShaw
I would also trim the values to remove any rogue spaces.
TRIM(Value)
For strings, I prefer String.Empty over ""
N ACHO
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
