How to null all iproperties with ilogic?
Message 1 of 10
I am looking for an easy way to clear iproperties, when I have copied an old part / assembly.
Any ideas for code on this?
Replies (9)
Message 2 of 10
Owner2229
Hi, if the iProperties' names are always the same (I assume you mean custom iProperties) then it is quite easy to do:
iProperties.Value("Custom", "PropertyName1") = ""
iProperties.Value("Custom", "PropertyName2") = ""
For Project iProperties:
iProperties.Value("Project", "Part Number") = ""
For assembly:
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim aDoc As DocumentsEnumerator = oDoc.AllReferencedDocuments
Dim iDoc As Document
For Each iDoc In aDoc
    'Here we clean iProperties in each of the parts in assembly
Dim sTS As String = iDoc.FullFileName
Dim FNamePos As Long = InStrRev(sTS, "\", - 1) Dim docFName As String = Mid(sTS, FNamePos + 1, Len(sTS) - FNamePos) iProperties.Value(docFName, "Custom", "PropertyName1") = "" iProperties.Value(docFName, "Custom", "PropertyName2") = "" Next
'Here we clean the assembly's iProperties iProperties.Value("Custom", "PropertyName1") = "" iProperties.Value("Custom", "PropertyName2") = ""
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 10
Hi Mike, thanks for your reply, however your assumption is wrong. I already have a way of clearing custom properties, I want to clear/null "Inventor Summary Information", "Design Tracking Properties" and "Inventor Document Summary Information" or even better ALL iproperties at once.
Message 4 of 10
Curtis_Waguespack
HI rki,
I just realized I had a rule to do this. In my case I use it to set "defaults" for each property (rather than clearing them). I do this for testing and then clear or set them using another rule. But the other rule has a lot of other stuff mixed in. So I've just made this rule clear/reset the iProperties for your needs.
So you can just change the test values at the beginning of the rule to modify this as needed. Note that it hits all of the iProperty collections including the custom iProperties.
I hope this helps.
Curtis
'[ wrap in a transaction to allow single undo
oApp = ThisApplication
Call oApp.TransactionManager.StartTransaction(ThisDoc.Document, "Clear All iProperties")
	' test values
	' change these as needed
	oString = ""
	oInteger = 1
	oBool = True
	oDate = Nothing
	oDoc = ThisDoc.Document
	'[ 'define custom property collection
	Dim oCustomPropertySet As PropertySet
	oCustomPropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
		For Each oProp In oCustomPropertySet
			If TypeOf oProp.Value Is Integer Then
				oProp.Value = oInteger
			Else If TypeOf oProp.Value Is Boolean Then
				oProp.Value = oBool
			Else If TypeOf oProp.Value Is String Then
				oProp.Value = oString
			Else If TypeOf oProp.Value Is Date Then
				iProperties.Value("Custom", oProp.Name) = oDate
			Else
		Next
	'[ 'define Summary Information property collection
	Dim oSUMProperties As PropertySet
	oSUMProperties = oDoc.PropertySets.Item("Inventor Summary Information")
		For Each oProp In oSUMProperties
				oProp.Value = oBool
			Else
		Next
	'[ 'define Design Tracking property collection
	Dim oDTProperties As PropertySet
	oDTProperties = oDoc.PropertySets.Item("Design Tracking Properties")
		For Each oProp In oDTProperties
				iProperties.Value("Status", oProp.Name) = oDate
				oProp.Value = oBool
			Else
			'Set creation time and design status
			'Currently being reset the same as anything else
			'But at one point these were being "reset" differently
			If oProp.Name = "Creation Time" Then
			iProperties.Value("Project", "Creation Time") = oDate
			ElseIf oProp.Name = "Design Status"
			iProperties.Value("Status", "Design Status") = oInteger
		Next
	'[ 'define Document Summary property collection
	Dim oDocSUMProperties As PropertySet
	oDocSUMProperties = oDoc.PropertySets.Item("Inventor Document Summary Information")
		For Each oProp In oDocSUMProperties
				oProp.Value = oBool
			Else
		Next
	iLogicVb.UpdateWhenDone = True
oApp.TransactionManager.EndTransaction
Message 5 of 10
Owner2229
Or simply this:
On Error Resume Next
Dim oPropSets As PropertySets
oPropSets = oDoc.PropertySets
Dim oPropSet As PropertySet
Dim iPro As Inventor.Property
For Each oPropSet In oPropSets
    For Each iPro In oPropSet
        iPro.Value = ""
    Next
Next
Or with ussage of Curtis' type selection:
oString = ""
oInteger = 1
oBool = True
oDate = Nothing
        If TypeOf iPro.Value Is Integer Then
	    iPro.Value = oInteger
	Else If TypeOf iPro.Value Is Boolean Then
	    iPro.Value = oBool
	Else If TypeOf iPro.Value Is String Then
	    iPro.Value = oString
	Else If TypeOf iPro.Value Is Date Then
	    iPro.Value = oDate
    Next
Next
Mike
Message 6 of 10
Hi Mike thanks again for your effort.
However the short version did not work (inventor crashed)
The longer version worked, but did not null the dates (uncheck)
The solution from curtis above does what I need, when I deleted his call in the beginning of the program.
Thanks again to you both.
Bset regards, Rasmus
Message 7 of 10
e_frissell
@Curtis_Waguespack
I'm working on a rule to do the same thing - I have one rule that publishes a bunch of stuff to about 20 different iProperties and for testing need an iLogic rule to clear them and have been trying to write a rule but I don't really understand why this one throws errors.  It seems like it should work, every iProperty is set to text so there shouldn't be a type mismatch but rather it simply doesn't run
The intent here is pretty clear as well - that the script should figure out how many iproperties there are, access each one by index, then set that value to "" but... errors.
Any help on this would be appreciated
Sub Main()
Dim i As Integer
Dim oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
i = 0
	oProp = oCustomPropertySet.Item(i)
	oProp.Value = "ST"
	i = i+1
Next
End Sub
Message 8 of 10
Curtis_Waguespack
@e_frissell
I'm not sure what this issue would be, but maybe you can try catching the error and reporting it to the logger.
I hope this helps.
Curtis
Sub Main()
'show ilogic logger
ThisApplication.UserInterfaceManager.DockableWindows.Item("ilogic.logwindow").Visible = True
For Each oProp as Inventor.Property In oCustomPropertySet
	Try
		oProp.Value = "ST"
	Catch ex As Exception
		Logger.Info("problem with: " & oProp.Name)
		Logger.Info(ex.Message)
	End Try
Next
End Sub
Message 9 of 10
WCrihfield
Hi guys.  I think I see the small detail.  You are setting 'i' to zero, then you are trying to get a Property at the index of zero from the PropertySet.  Inventor based collections all start at index 1, not zero.  VB.NET collections usually start at index of zero though.  Plus, you are not checking the Count of the PropertySet first.  If it did not have any Properties in it, that might cause a problem.  Plus, if the document was ReadOnly for some reason, it might cause a problem.  Using the Try...Catch statement like Curtis suggested is a great idea when working with custom iProperties though.
Wesley Crihfield
(Not an Autodesk Employee)
Message 10 of 10
e_frissell
OHH!! Trying to access an index value that doesn't exist would do it!  I'm surprised it didn't throw an index error for the index not existing
You're right about the i also!  It was written as for i = 0 to oCustomPropertySet.Count which didn't work then re-tried with the for each loop
Just rewrote it using for i = 0 to .count and it runs
