第 1 条消息(共 33 条)
不适用
03-15-2018
07:36 AM
I am runnign an Ilogic script every file on save. The problem is that if this file is new, and hase never been checked in into vault before, then the vault window appears and has to be closed. I would like to run the script only if the file has already beed in vault once before. Is there a way to check this from within Ilogic? Thanks!
已解决! 转到解答。
