Fail to get PlanarSketch.Dependents(.Count) Property ("Not implemented" Exception)
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
Dear @MjDeck
Could you, please, comment if it is normal that Inventor produces the "Not implemented" Eexception on attempt to get PlanarSketch.Dependents(.Count) Property on the IPT (2024) attached?
I'm using this iLogic-code:
Dim partDoc As PartDocument = ThisDoc.Document ' ThisPart
' Dim compDef As PartComponentDefinition = partDoc.ComponentDefinition
Dim compDef As ComponentDefinition = partDoc.ComponentDefinition
' Dim sk As PlanarSketch = compDef.Sketches(1)
For Each sk As PlanarSketch In compDef.Sketches
	Logger.Info(sk.Name)
	Try
		Logger.Info(vbTab & ".Dependents: " & sk.Dependents.Count)
	Catch ex As Exception
		Logger.Error(vbTab & ex.Message) ' Not implemented (Exception from HRESULT: 0x80004001 (E_NOTIMPL))
	End Try
Next
PS:
I see the error is somehow related to the fact that End-of-Part marker is not at the top or bottom position (the code produces no exceptions when EoP moved to either top or bottom position).
Please vote for Inventor-Idea Text Search within Option Names
bradeneuropeArthur
This works for Inventor 2025:
	MsgBox(sk.Name)
	Try
		MsgBox(vbTab & ".Dependents: " & sk.Dependents.Count)
		msgbox(vbTab & ex.Message) ' Not implemented (Exception from HRESULT: 0x80004001 (E_NOTIMPL))
	End Try
Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
MjDeck
Thanks Arthur. I confirmed that Maxim's original code works in 2025 as well.
@Maxim-CADman77 , it looks like there is a problem in 2024. But it's not only caused by end-of-part. Moving the EOP does not cause this error in all parts.
But in the part you posted, in both 2024 and 2025, if you drag the EOP to the bottom there will be update errors in Extrusion15 and the sketch it consumes.
Mike Deck
Software Developer
