Itterates through Each Sub Assembly of a TOP Assm, then Sort & Renumber Structured BOM.
G.Binl
G.Binl
Hi all,
I have some code that separately works great.
1. Opens each Sub Assemblies and displays them. (1A &1B) remove (2)
2. Sorts Structured BOM and renumbers them.  (2) remove (1A&1B)
When I merge them no go. It seems to jump right over 2.
Code is below.
open sub assemble
2A before code (2)
2B After Code (2)
Here is the code.
Dim oDoc As Inventor.Document
Dim oRefDoc As Inventor.Document
Dim oCompDoc As Inventor.Document
  oDoc = ThisApplication.ActiveDocument
For Each oRefDoc In oDoc.ReferencedDocuments
    If oRefDoc.IsModifiable Then
          oCompDoc = ThisApplication.Documents.Open(oRefDoc.FullFileName)
        If oCompDoc.ReferencedDocuments.Count > 0 Then
'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Dim oAsmDoc As AssemblyDocument
Dim oAsmCompDef As AssemblyComponentDefinition
Dim oBOMView As BOMView
oAsmDoc = ThisDoc.Document
oAsmCompDef = oAsmDoc.ComponentDefinition
oBOMView = oAsmCompDef.BOM.BOMViews.Item("Structured")
oBOMView.Sort("BOM Structure", 0, "Subject", 1, "Description", 1)
'oBOMView.Sort("Item", 1)
oBOMView.Renumber(300)
        oCompDoc.Close
Next
A.Acheson
Hi @G.Binl
The issue is using the below line. This is referencing the main assembly you launch the rule from.
 Use the document object when opened which is oCompDoc
oAsmCompDef = oCompDoc.ComponentDefinition
 Or you actually don't need to open it because it is allready opened in the context of the assembly so just reference the referencedDocument.
oAsmCompDef = oRefDoc.ComponentDefinition
Regards
Alan
G.Binl
Thank @A.Acheson  Now I See my Error, Works like a charm. This will allow so much flexibility for what we do. have a great week end.
