Extract numbers from string
Message 1 of 11
I need to write a rule that will extract either one or two numbers from a string.
For example, the results from these string would be as follows:
Bar round 35.0mm x 3m mild steel
  1. 35.0
Section box 30 x 30 x 3mm mild steel
  1. 30
  2. 30
Bar flat 80 x 8mm x 6.1m mild steel
  1. 80
  2. 8
Rod 5 mm x 3mt stainless steel grade 304
  1. 5
Its essentially the first two numbers that are separated by an "x", but I'm thrown a curve ball when I only need one number returned.
The other issue I need to overcome is that the format is not always consistent, for example some entries:
  • may not always have a space either side of the "x"
  • might include a space between the number and "mm"
  • metre will be written as "m" and other times it will be "mt" or "mtrs"
Any tips on how to achieve?
Replies (10)
Message 2 of 11
frederic.vandenplas
Hi @Anonymous
The inconsistency of data and programming is in the case of working with strings a big problem, i don't know the background for this, but when i receive inconsistent data, i would throw it back Smiley Wink (easier said then done, i know)
This should help you for the examples you provided, i hope someone else posts a magical solution for you, i could learn from this
 too
Sub GetStrings()
Dim str1 As String
str1 = "Bar round 35.0mm x 3m mild steel"
'str1 = "Section box 30 x 30 x 3mm mild steel"
'str1 = "Bar flat 80 x 8mm x 6.1m mild steel"
'str1 = "Rod 5 mm x 3mt stainless steel grade 304"
Dim str() As String
str = Split(str1, " ")
If InStr(str1, "Bar round") <> 0 Then
MsgBox Replace(str(2), "mm", "")
ElseIf InStr(str1, "Section box") <> 0 Then
MsgBox str(2)
MsgBox str(4)
ElseIf InStr(str1, "Bar flat") <> 0 Then
MsgBox str(2)
MsgBox Replace(str(4), "mm", "")
ElseIf InStr(str1, "Rod") <> 0 Then
MsgBox str(1)
End If
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Message 3 of 11
MechMachineMan
Sub GetStrings()
Dim str1 As String
Dim str() As String
str = Split(str1.ToUpper, "X")
MsgBox(ExtractNumbers(str(0)) & vblf & ExtractNumbers(str(1)) & ExtractNumbers(str(2)))
End Sub
Function ExtractNumbers(oField1 As String) As String
'Extracts the FIRST set on continuous numbers from the field.
oField1 = TRIM(oField1)
For each c as Char in oField1
If IsNumeric(c) = True Then
OutString = OutString & c
Else
If OutString <> ""
Exit For
End if
End if
Next
ExtractNumbers = OutString
ENd Function
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 4 of 11
@frederic.vandenplas thanks,
it's the same everywhere, CAD managers tidying up procurements mess Smiley Tongue
I can work with your code, although I would prefer not to differentiate between the different types of section (as thats not always consistent either!!!)
Message 5 of 11
Hi @MechMachineMan
I got these results with your code
  • Bar round 35.0mm x 3m mild steel
Index was outside the bounds of the array.
  • Section box 30 x 30 x 3mm mild steel
3030
  • Bar flat 80 x 8mm x 6.1m mild steel
80
86
  • Rod 5 mm x 3mt stainless steel grade 304
Message 6 of 11
This is my attempt, which is pretty long and drawn out.
I'm getting the two numbers, but I just need a way to set the 2nd number to null if its not required
oMaterial1 = "R00001 - Bar round 35.0mm x 3m mild steel"
'oMaterial1 = "R00002 - Section box 30 x 30 x 3mm mild steel"
'oMaterial1 = "R00003 - Bar flat 80 x 8mm x 6.1m mild steel"
'oMaterial1 = "R00004 - Rod 5 mm x 3mt stainless steel grade 304"
Dim oMaterial2 As String = Right(oMaterial1, Len(oMaterial1)-9)
'MsgBox(oMaterial2)
Dim count As Integer = 0
Dim myChars() As Char = oMaterial2.ToCharArray()
For Each ch As Char In myChars
     If Char.IsLetter(ch) Then
         count = count + 1
       ' MessageBox.Show(ch)
     ElseIf Char.IsWhiteSpace(ch) Then
         count = count + 1
         'MessageBox.Show(ch)
     ElseIf Char.IsDigit(ch) Then
         Exit For
    End If
Next
'MsgBox(count)
Dim oMaterial3 As String = Right(oMaterial2, Len(oMaterial2)-count)
'MsgBox(oMaterial3)
numCount1 = 0
Dim myNums() As Char = oMaterial3.ToCharArray()
For Each ch As Char In myNums
         Exit For
         Exit For
         numCount1 = numCount1 + 1
    ElseIf Char.IsPunctuation(ch) Then
    End If
Next
Dim strNum1 As String = Left(oMaterial3,numCount1)
MsgBox(strNum1)
Dim oMaterial4 As String = Right(oMaterial3, Len(oMaterial3)-numCount1)
'MsgBox(oMaterial4)
numCount2 = 0
Dim myNums2() As Char = oMaterial4.ToCharArray()
For Each ch As Char In myNums2
         numCount2 = numCount2 + 1
        Exit For
    End If
Next
Dim oMaterial5 As String = Right(oMaterial4, Len(oMaterial4)-numCount2)
'MsgBox(oMaterial5)
numCount3 = 0
Dim myNums3() As Char = oMaterial5.ToCharArray()
For Each ch As Char In myNums3
         Exit For
         Exit For
         numCount3 = numCount3 + 1
    End If
Next
'Dim oVal As String = Right(oMaterial5, Len(oMaterial5)-numCount3)
'MsgBox(oVal)
'unit = Left(oVal,2)
'MsgBox(unit)
'If unit = "mm" Then
Dim strNum2 As String = Left(oMaterial5,numCount3)
MsgBox(strNum2)
'Else
'strNum2 = ""
'End If
Message 7 of 11
pball
Here is my voodoo magic. It seems to work in the scenarios provided. It always provides the two numbers at the moment though.
Is there a rule for when only one number is needed? Is that input on your end or something that could be determined from the input string?
Sub numbers()
    oMaterial1 = "R00001 - Bar round 35.0mmx3m mild steel"
    Dim regex As Object
    Dim regexMatches As Object
    Set regex = CreateObject("vbscript.regexp")
    regex.IgnoreCase = True
    regex.Global = True
'Voodoo Magic regex.Pattern = " ([\d\.]+).*?(| )x(| )([\d\.]+).*? " Set regexMatches = regex.Execute(oMaterial1) Debug.Print regexMatches.Item(0).submatches.Item(0) & " -- " & regexMatches.Item(0).submatches.Item(3) End Sub
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Message 8 of 11
perrysc
Hope this works for you
Sub Main()
    Dim oRawString As String = "Rod 5 mm x 3mt stainless steel grade 304" 'your string goes HERE
    Dim oMessage As String = "Raw String:" & vbLf & oRawString & vbLf & "Extracted Values:"
    Dim oValues As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
    Call _StringDefragifier(oRawString,oValues)
    For i As Integer = 1 To oValues.Count
        oMessage = oMessage & vbLf & oValues.Item(i)
    Next
    MsgBox(oMessage)
End Sub
Sub _StringDefragifier(oRawString As String,oCollection As ObjectCollection)
    Dim oWorkingString As String = _RemoveExtraneous(oRawString)
    Dim oFirstValue As String = _GetNumeric(oWorkingString)
    oWorkingString = Right(oWorkingString,Len(oWorkingString)-Len(oFirstValue))
    oCollection.Add(oFirstValue)
    oWorkingString = _RemoveExtraneous(oWorkingString)
    Dim oSecondValue As String = _GetNumeric(oWorkingString)
    oWorkingString = Right(oWorkingString,Len(oWorkingString)-Len(oSecondValue))
    Dim oCharsToNextValue As Integer = 0
    For i As Integer = 1 To Len(oWorkingString)
        If Not IsNumeric(Mid(oWorkingString,i,1)) Then
            oCharsToNextValue += 1
        Else
            Exit For
        End If
    Next
    If oCharsToNextValue < 9 Then 'Careful - assumes characters between dimensions no greater than 8
        oCollection.Add(oSecondValue)
    End If
End Sub
Function _RemoveExtraneous(oString As String) As String
    For j As Integer = 1 To Len(oString)
        If IsNumeric(Mid(oString,j,1)) Then
            _RemoveExtraneous = Right(oString,Len(oString)-(j-1))
            Exit For
        End If
    Next
End Function
Function _GetNumeric(oString As String) As String
    Dim oDummyValue As String = ""
        If Not Asc(Mid(oString,j,1).ToUpper)>=Asc("A") AndAlso Not Asc(Mid(oString,j,1).ToUpper)>=Asc("Z") Then
            oDummyValue = oDummyValue & Mid(oString,j,1)
        Else
            _GetNumeric = oDummyValue
            Exit For
        End If
    Next
End Function
Message 9 of 11
@pball
Looks interesting, I'll need to wait till tomorrow to try it out.
I guess a rule could be when there are 3 numbers then the first 2 are returned and when there are 2 numbers then the 1st number is returned
Message 10 of 11
@perrysc
Spot on!
+ it handles imperial UoM as well Smiley Very Happy which was my next worry
Message 11 of 11
perrysc
No problem, glad to help.
