Two diameters... non iLogic solution?
oransen
oransen
I have a cylinder with a diameter DiamAtt and it has some material taken away by another cylinder, with a diameter of DiamColl. Here's a picture:
So when DiamColl or DiamAtt changes Dcoll is calculated.
I have the iLogic to calculate Dcoll:
Dim RagColl as Double
Dim RagAtt As Double
RagColl = DiamColl/2.0
RagAtt = DiamAtt/2.0
If RagAtt < RagColl Then
    Dcoll = Sqrt((RagColl*RagColl) - (RagAtt*RagAtt))
Else
    Dcoll = 0.0
This works, but the triggering of the rule seems a bit hit and miss. So my question is:
Is there a way of achieving this without iLogic but directly inside the parameter formula column?
TIA!
MechMachineMan
You better believe it.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
sign(ragcoll - ragatt) - returns 0 if negative, 1 if positive -- your if statement when used multiplicatively
sign(ragcoll*ragcoll -ragatt*ragatt) -- needed because Sqrt(negative number) returns "nan(ind)"
THUS:
in one line:
sign(ragcoll - ragatt)*SQRT((ragcoll*ragcoll - ragat*ragatt)*sign(ragcoll*ragcoll-ragatt*ragatt))
Returns 0 =  0 * SQRT((ragcoll*ragcoll - ragat*ragatt)*0) if ragcoll < ragatt
returns SQRT((ragcoll*ragcoll - ragat*ragatt) =  1 * SQRT((ragcoll*ragcoll - ragat*ragatt)*1 if ragcoll > ragatt
Also, be careful of your units.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
CattabianiI
Try this:
sign does the work of your If
abs avoids the square root on negative numbers
sign(RagColl - RagAtt)
sqrt(abs((RagColl*RagColl) - (RagAtt*RagAtt))) * ifRes
Anyway, for your iLogic code, make sure you haven't checked the "Don't run automatically" in the iLogic options.
CattabianiI
I just read the @MechMachineMan's answer that get also the sign of the argument of sqrt, and it clearly works, but if RagColl is less than RagAtt, Dcoll is equal to -0, yeah don't worry and treat that -0 as zero, but getting negative sign by the square root can be weird.
oransen
Thanks all for you help!
